Question About Mirrors
Old 02-03-2018, 02:56 PM
45FMJoe's Avatar
45FMJoe
45FMJoe is offline
I have a '79 Bronco Custom. I recently found out, thanks to Bill, that Customs did not come with the side molding standard. I always assumed someone filled in the holes when they repainted the truck. I pulled the door panel and found there were never holes for molding. Awesome, good to know. but my question is about my side view mirrors, the bottom bolts are in the molding channel. I've never seen mirrors mounted in the dent before, always right above the dent. There were no holes in the door above the mirror. So, has anyone seen these mirrors mounted this way before?
Old 02-03-2018, 03:28 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 45FMJoe
I have a '79 Bronco Custom. But my question is about my side view mirrors, the bottom bolts are in the molding channel. I've never seen mirrors mounted in the dent before, always right above the dent. There were no holes in the door above the mirror. So, has anyone seen these mirrors mounted this way before?
1973/79 F100/350: There were SEVEN different types of TYPE 9 Low Mount "Swing-Lock" Mirrors.
Since the dealers installed all the outside mirrors, 1978/79 Bronco's could have any one of these types.
Old 02-04-2018, 12:58 AM
79time's Avatar
79time
79time is offline
4wd Low
Here is data listing the mirror options in 79.
Old 02-04-2018, 05:38 AM
rob8210's Avatar
rob8210
rob8210 is offline
I have never seen a mirror with the bottom mount in the dent like that.
Old 02-04-2018, 06:59 AM
twinzilla's Avatar
twinzilla
twinzilla is offline
I've seen them mounted like that before, but I don't know if it's correct (since the dealers were responsible for installing the mirrors, anything is possible).
Old 07-24-2018, 08:51 AM
milkweed.gardener's Avatar
milkweed.gardener
milkweed.gardener is offline
It looks to me that 79time's data listing image, the upper left mirror is what you have,
and that comparing your mirror to that one in the data listing, your's is mounted too low causing the lower hanger to be in the dent
in the data listing image, you can see the side trim forces the mirror to be mounted higher
What about the mirror on your passenger door, is it mounted the same way?
Old 07-24-2018, 02:09 PM
The Peddler's Avatar
The Peddler
The Peddler is offline
It seems to me that most-assuredly yours are not mounted correctly, as the end "Arm" at the lower bracket is contacting the paint.
Old 07-24-2018, 03:01 PM
milkweed.gardener
If the passenger mirror is mounted the same way, no need to fret.
It looks good regardless.
Old 07-24-2018, 03:28 PM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
Looks like a case of "re- engineering". The pic in the upper left in the listing shows the arm at an upward angle from the door. Pic in post #1 ,the arm is straight out from the door, moving the lower mounting bracket down into the channel.
Old 07-24-2018, 04:32 PM
1TonBasecamp's Avatar
1TonBasecamp
1TonBasecamp is offline
Yes, those are the Delbar brand of mirrors, and yes the customs did not automatically come with trim. The picture shows how mine are mounted too.
Although, it looks to me like the installer of yours went to the extra effort to spread the hoop so they could be mounted higher up on the door and the lower mount would still fit into the dent. Nice.
Also used the same model in black, but painted Peacock Blue and Wimbledon White to match the paint on the Bronco.
Paul
Old 07-24-2018, 04:39 PM
1TonBasecamp
Interesting. Is that a Ford brochure, or something else?
Notice that the Swing-Lock mirrors in the upper left are in fact the same Delbar style as ours. Same mounting feet and arm shape that put the upper bar at an angle, instead of being level like the factory Ford mirrors were.
The actual Ford type-9 Swing-Lock mirrors have different mounting feet and are obviously shaped for the trucks. With the Delbars right out of the box you have to tweak the arms for a better fit. And even more if you have the trim and can't mount the lower foot inside the dent like in the brochure's pic.
Interesting.
Paul
Old 07-24-2018, 10:41 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Received 3,421 Likes on 2,539 Posts
IMO those are a bit newer Ford truck (80's ish) mirrors put on a dentside and NO that is not where they are suppose to be (in the dent) if they were actual 73-79 Type 9's. If they work and match, then let it go or get 73-79 type 9's and get to dril 2 more holes.
Old 07-25-2018, 12:11 PM
milkweed.gardener
since reading this thread I have begun to notice other trucks with their type 9 mirrors mounted in the channel/dent
I spotted two on CraigsList
https://athensga.craigslist.org/cto/...644357656.html
https://atlanta.craigslist.org/nat/c...620866734.html
Old 07-26-2018, 09:03 AM
milkweed.gardener
wow, this one has it mounted below the dent
https://limaohio.craigslist.org/cto/6653569403.html
Old 07-26-2018, 11:28 AM
1TonBasecamp
In that low position you have to be sittin' pretty tall in the saddle to make much use of the passenger side mirror I would think.
Paul
Quick Reply: Question About Mirrors
