bogging down under acceleration
Old Sep 15, 2003 | 07:46 AM
rusty78's Avatar
rusty78
I bought my truck back in February and hadn't had a problem with anything until recently. The intake manifold gasket blew out at the rear, causing the truck to backfire through the carburetor. I replaced the intake gasket and had the carb rebuilt. Now, I can get the truck to start and idle fine but it wants to bog down when you press the accelerator. It stumbles whether it's in park, neutral or under load. I've checked the timing and made sure there are no vaccum leaks (it's running at a steady 20 inches of vaccum) and also adjusted the carb until I'm blue in the face. The truck ran fine before the gasket went out so I'm at a loss as to what the deal is. Anybody have any ideas? Thanks in advance.
Old Sep 15, 2003 | 08:02 AM
rusty78's Avatar
rusty78
p.s. I forgot to metion that this is a '78 F-250 with a 351m and an automatic. sorry
Old Sep 15, 2003 | 08:55 AM
ranger429's Avatar
ranger429
what kind of carb? motorcraft? could be the accelerator pump gone bad
Old Sep 15, 2003 | 08:57 AM
beartracks's Avatar
beartracks
You might need to adjust the accelerator pump.
Old Sep 15, 2003 | 10:33 AM
rusty78's Avatar
rusty78
It is a Motorcraft 2 barrel. I just had it rebuilt so i figured it should be ok, how do you adjust the accelerator pump? thanks for the advice
Old Sep 15, 2003 | 12:13 PM
beartracks's Avatar
beartracks
I think that has the same pump set up as a Holley. With the engine off look down the through the carb and give it a little gas. Choke should be all the way off. You should see an immediate squirt of gas out of the nozzles in the top part of the carb. If not there is a screw and spring assembly that pushes on the diapram lever. That's the adjustment.
Old Sep 15, 2003 | 01:19 PM
rusty78's Avatar
rusty78
Thanks for the advice. I'm going to check that out and see what happens. Worse case, I'll be back asking more questions. Thanks again
Old Sep 15, 2003 | 01:21 PM
macguyver's Avatar
macguyver
Also, check the vacuum advance diaphragm.
hail destroyer
Oct 2, 2016 06:32 PM
theoldfseries523
Nov 30, 2014 08:21 PM
5th One
1997 - 2003 F150
Nov 12, 2014 06:57 AM
Fordzilla80
1983 - 2012 Ranger & B-Series
38
Sep 26, 2011 10:25 AM
albcasummit
Feb 10, 2007 09:26 AM
