Ignition Coil?
Old Feb 4, 2018 | 11:05 AM
WE3ZS's Avatar
WE3ZS
Originally Posted by WyoX
Thanks Tom.
Stewart also says replace the boots to start with. I will take the advice given here by all and start with that, along with changing plugs. That is the least expensive route.
I have read the procedure on changing plugs. Should have no problem. When wrenching on anything, my motorcycles and guns included, I do it all by feel and never get western on anything with a tool. I know how to use some finesse.
Do yourself a favor here and use a torque wrench when installing the new plugs, your ;00 heads only have 4 threads and its pretty important to not have them too loose or too tight.
Old Feb 4, 2018 | 11:39 AM
WyoX's Avatar
WyoX
Sounds good. You mentioned torque specs in a previous post. Is it 11 ft/lbs. or 26/28 ft/lbs? I was confused with the numbers in your comments.
"'00/'03 spec calls for 11 ft/lbs and '03/'05 is 17 ft/lbs, I have an '05 and used 32 ft/lbs. Many owners of the earlier build trucks (like yours) with the fewer threads have had good luck with 26/28 ft/lbs."
Old Feb 4, 2018 | 01:59 PM
WE3ZS's Avatar
WE3ZS
The semi-common issue of plug blowouts on early 4 thread head modular motors is blamed in part by some on the very low 11 ft/lb factory torque spec, it really is just about hand tight. Many owners of these motors have had very good luck with over torqueing the plugs up to the 26/28 ft/lb range which seems to keep them well seated for the long run. Many also recommend a recheck of the torque after 5 or 10K miles to ensure they are holding tight. In mid-year '03 Ford increased the number of spark plug threads on these motors to about 7 and the increased the torque spec to 17 ft/lbs. This seems to have greatly reduced the plug blowout issues. Even that higher spec still seems low to me (and many others) so I went with the 32 ft/lbs setting when I changed my '05's plugs.
Old Feb 4, 2018 | 02:15 PM
WyoX's Avatar
WyoX
I didn't realize it was due to the low torque of the plug.
Makes sense with only four threads. Wouldn't take much to loosen up.
Thanks again for the info.
Old Feb 4, 2018 | 08:52 PM
WyoX's Avatar
WyoX
Tom, thanks for the suggestion on Rock Auto.
Denso COP boot kit shipped to me for $36. Local parts store wanted $80
I usually spend my money locally, but in this case it saved me quite a bit buying the boots on-line.
Old Feb 5, 2018 | 07:38 AM
wpnaes's Avatar
wpnaes
Originally Posted by projectSHO89
Ohmmeter checks of COPs is usually a waste of time.
Oscilloscope diagnosing on the other hand is mesmerizing .
Originally Posted by Stewart_H
Replacing the old COP boots with new ones isn't very expensive and it's a great preventive maintenance job that...one could argue...has perfect timing!
Stewart
Heck, do the plugs while you’re in there that deep.
Old Feb 5, 2018 | 08:36 AM
WyoX's Avatar
WyoX
https://youtu.be/gmjS5qXp3sU
I got plugs too. Not looking forward to doing the back of the right bank.
I remember doing engine diagnostics on an old SUN machine when I was in high school auto mechanics class back in 78'-79'. That old machine I believe was from the 60's. LOL
Old Feb 5, 2018 | 08:55 AM
wpnaes's Avatar
wpnaes
Yeah, number 5 is a pain, get a wobble extension and take your time.
I think taking off the triangle shaped piece (3 bolts) makes it easier.
Old Feb 5, 2018 | 01:49 PM
WyoX's Avatar
WyoX
Yeah, going to have to remove some stuff out of the way. My problem is having a bad back and leaning over close enough to reach it.
I may have to crawl up in there to get to it. I barely got to the coil connector plug when I removed it troubleshooting.
Rock Auto shipped my plug boots today. Should see them Friday. Will have to work in the cold weather doing this. My garage is not big enough for the Excursion to fit in. :/
Old Jun 17, 2018 | 01:20 AM
WyoX's Avatar
WyoX
Been a while since I have posted. Wanted to thank everyone for the help. I did get all plugs and boots replaced.
The trouble wound up being a simple coil replacement on number 6 cylinder. Been running great ever since.
Old Jun 17, 2018 | 12:26 PM
Stewart_H's Avatar
Stewart_H
Excellent follow-up to bring closure to the thread.
Stewart
Old Jun 17, 2018 | 06:51 PM
WE3ZS's Avatar
WE3ZS
Thanks for the follow up, great to hear that another mighty V-10 is running perfectly!
Old Jun 17, 2018 | 10:38 PM
  #28
WyoX's Avatar
WyoX
The info that was provided was very valuable. Without soaking the plugs prior to removal, and not torquing them to the correct specs, the outcome may have been entirely different.
rsanford
Jul 2, 2013 12:08 PM
SCRWDRVR
2004 - 2008 F150
Feb 23, 2012 06:26 PM
fire105
1997 - 2003 F150
Apr 6, 2007 11:59 AM
eslfuzzy
1997 - 2003 F150
Jan 26, 2007 02:32 PM
jgrm2
1997 - 2003 F150
Mar 24, 2004 11:22 AM
