2002 E350 should have 4R100.
Count the pan bolts, 4R100 has 20
4R70 has 14.
4R100 pan is shaped like Utah, 4R70 like a fat baseball home plate with the top point cut off.
Each one has a filter in the transmission.
The 4R70W was never mated to a V10. It has the 4R100.
It does have a filter, and that filter doesn't need to be changed until the trans is rebuilt. If you decide to change it anyways, it requires a 4x4 filter regardless of what the parts store lookup says.
