Sponsored by: Real Truck
Trans filter difference??
Old Dec 1, 2017 | 07:13 PM
Keeth's Avatar
Keeth
Quick easy question! I went to the part store to get two trans filters. One for my 1998 ford f250 light duty 5.4. (Which I thought was an e40d) 2 wheel drive. And one for my f350 dually v10 4x4. However they said the only option for my f250 was a 4r100 not the E40d. My id tag is labeled with an "E". My question is, is the filter the same for an E40d and a 4r100 2 wheel drive tranny. I know the 4x4 had deeper pick ups but I feel like the "B" team (late night/weekend works) may have sold me the wrong filter. Thanks!
Old Dec 1, 2017 | 07:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You're right on the cusp of a couple changes. I'm not certain of exactly what was built in the 1998 models. Both E4OD and 4R100 had the E code on the ID tag.
E4OD had both deep and shallow pans. 4R100 only used the shallow pan on the Lightning trucks as I remember it.
Your V10 truck will have a deep pan. Is the E4OD pan the same depth as the V10? You could measure it without taking either pan off.
Old Dec 1, 2017 | 08:04 PM
Keeth's Avatar
Keeth
Well one filter the v10 4x4 filter has a different part number. Than the 250ld I can run out and look. I just don't wanna drain everything and have the wrong filter. As long as the E40d 2x4 has the same filter as the 4r100 2x4 i should be good right?
Old Dec 1, 2017 | 11:41 PM
Sam I Am's Avatar
Sam I Am
One way I know of to tell for sure is to drop the pan and filter and look at it.
I am pretty sure that 98 is a 4R100. Every 97-03 of that body style I have looked up the VIN on with the larger transmission (not 4R70W) has been labeled "E4OD(4R100)" up through model year 2003.
Old Dec 4, 2017 | 09:45 PM
Mechanaut's Avatar
Mechanaut
Filter is the same for E4OD/4R100 1989 - Up.
Old Dec 4, 2017 | 09:55 PM
Keeth's Avatar
Keeth
Over the weekend i flushed both trucks and changed the filters. The filter on my dually was incorrect go figure. I spent the better part of a hour trying to figure out why it had the short inlet. Eventually I put the new one with the long inlet in and all is well. My f250 had the right filter and went seamlessly. All is well and shifting goooooood. Thanks you guys.
Old Dec 4, 2017 | 10:00 PM
Mechanaut's Avatar
Mechanaut
Excellent!
ArmyLifer
Apr 11, 2017 01:20 PM
Skylaneman
May 17, 2015 09:13 PM
Farmboypowerstroke
May 10, 2010 09:58 PM
linckeil
16
Sep 17, 2009 12:03 AM
SpringerPop
May 5, 2009 04:49 PM
