2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Wheel stud replacement
Old Feb 1, 2018 | 11:12 AM
carolinaborn82's Avatar
carolinaborn82
Had three wheel studs break on my 07 Expedition. What is the best way to replace them? The replacement studs are cheap. Hope the actual labor isn't to difficult.
Old Feb 1, 2018 | 12:35 PM
alloro's Avatar
alloro
Which wheel, 2wd or 4wd?
Old Feb 1, 2018 | 12:51 PM
carolinaborn82
2wd. Rear wheel
Old Feb 1, 2018 | 01:00 PM
alloro's Avatar
alloro
With a large hammer and a punch knock the broken studs in until they fall out. Then work a new stud into place, use a spacer over the threads (thick washers) but leave some threads showing. Then install a lug nut on the stud and tighten it until the new stud is pulled all the way into place. Lube the stud hole and stud threads with WD-40 to help the installation go a easier.
Old Feb 1, 2018 | 01:05 PM
alloro's Avatar
alloro
Here's a video showing you how to do what I wrote above.
Old Feb 1, 2018 | 02:53 PM
carolinaborn82
https://www.youtube.com/watch?v=0xjPBFsLT94
Thank you very much. I thought this was gonna be an expensive fix.
Old Feb 2, 2018 | 10:49 AM
alloro's Avatar
alloro
If the hub is old you might want to think about replacing it since it will come with new studs installed. No sense changing the studs if you're going to be changing the hub soon anyways. Just a thought.
Old Feb 22, 2018 | 11:40 AM
carolinaborn82
OK guys. Need more help. I got the brake caliper and rotor off. Then I see a plate behind the caliper that the actual studs go into. It looked like it was held on by the axle bolt. So I took it off and it still won't budge. I feel like I have to take that plate off because I don't have enough room behind it to get the old studs out and the new ones in. What do I do next guys?
Old Feb 23, 2018 | 08:04 AM
alloro's Avatar
alloro
You don't have to take that plate off, besides I doubt you can without a hydraulic press. Just try knocking one of the studs in, you'll see that once it's loose you'll be able to angle it to get it out and in.
Old Feb 26, 2018 | 03:28 PM
carolinaborn82
Getting the broken studs out. I can get the new stud behind the plate, but i don't have enough depth to get it in the hole. What am i doing wrong here guys?
Old Feb 27, 2018 | 06:09 AM
carolinaborn82
Old Feb 27, 2018 | 08:23 AM
alloro's Avatar
alloro
Did you try turning the axle to a different position where the backplate might have a low spot?
Old Feb 27, 2018 | 09:04 AM
carolinaborn82
There really isn't a low spot. I can look again. But it's pretty right all the way around.
Old Feb 27, 2018 | 10:48 AM
alloro's Avatar
alloro
Maybe you have to remove the brake shoes so you can get enough angle behind the plate. The stud is designed to go in this way, you just have to find the position that works.
MainetoDC
Feb 2, 2018 02:10 PM
dark_flame221
May 4, 2010 09:23 AM
bigblockgearhead
Mar 30, 2006 11:11 AM
ferguson777
Dec 5, 2002 11:18 AM
maldb
Oct 1, 2001 01:48 PM
