Sponsored by: Real Truck
Replacing door locks
Old Feb 1, 2018 | 09:43 AM
MTP55's Avatar
MTP55
I am going to replace my locks on my doors. Last weekend had someone put an item in my truck maybe as a inappropriate joke. Nothing was missing. I figure maybe was a "buddy" that isn't speaking to me right now. My locks haven't worked because they're froze up. The doors will lock but I can't get back in. No keypad or remote entry just a standard key lock. I know Napa has a kit for about $40. I imagine you need to remove the interior door panel to remove the old locks and install the new ones correct? My other trucks door panel is held on with screws but this one is newer so probably has plastic tabs. The truck is a 2000 F-250 crew cab lariat trim package. Thanks in advance.
Old Feb 1, 2018 | 10:47 AM
jetty's Avatar
jetty
Door panels come off, which is super easy. Just remove 2 screws, lift one inch and pull panel away from door.
Old Feb 1, 2018 | 02:48 PM
MTP55's Avatar
MTP55
Good deal! Was scared it'd be like a lot of other vehicles that had all those goofy tabs that break.
Old Feb 1, 2018 | 03:42 PM
brian42's Avatar
brian42
Veteran: Navy
No goofy tabs to break. Make sure you remove the switch panel from the door so you can unplug the assembly and get to one of the screws. IIRC the other one is behind the courtesy lamp cover at the bottom of the door.
Old Feb 1, 2018 | 03:46 PM
MTP55's Avatar
MTP55
Does it just pop off? Courtesy lamp is easy already had them open because none of them turn on in the truck. (Found out a fuse is missing with the scanner)
Old Feb 1, 2018 | 04:29 PM
brian42's Avatar
brian42
Veteran: Navy
The lamp cover? Yes. Small flat blade screwdriver in the slot and you can pop the courtesy lamp cover off.
Once you remove the switch panel, both screws and the sail cover (small triangle that covers the rearview mirror nuts at the top of the door panel), you can slowly lift the door and it will come out of the guide slots (the door handle is mounted to the door itself so there's no rod to un-clip or remove from the handle). Don't pull too far as you still have to reach back there and remove the courtesy light socket (a simple 90 degree twist and it's out). After that you can set the door aside and you're in!
Old Feb 1, 2018 | 07:53 PM
MTP55's Avatar
MTP55
Perfect. Thanks.
Markadeck
May 12, 2008 04:43 PM
bones68
Jan 14, 2006 12:56 PM
mrmootsie
Mar 21, 2004 07:43 AM
firstford
Oct 20, 2003 09:33 PM
Mykro
Oct 3, 2003 02:45 PM
