High Beam Wire?
Old Feb 5, 2018 | 06:14 PM
marobrown's Avatar
marobrown
Body control module
Old Feb 6, 2018 | 02:47 AM
vtfireftr's Avatar
vtfireftr
I also used a DPST switch in my truck. But I used the switch for the ground.
One side of the switch is always on, the other is when the high beams are on.
I use a signal from the high beams to control the relay to complete the ground.
This way, no stray voltage going back into the cab or causing issues elsewhere.
Old Feb 6, 2018 | 05:41 AM
marobrown's Avatar
marobrown
I considered this as well as I have always hooked up lights before by switching the ground to keep the power wires as short as possible, well I have since I was about 16 and caught my old 68 C10 on fire by wiring up some lights and wasn’t smart enough at the time to use relays and fuses. But that’s a different story lol.
I wired up my buddies light bar on his truck last year that is only controlled by a switch, used the ground through the switch. He drove around for a few hours one day (daylight hours) getting flashed and wasn’t sure why until the police told him his light bar was on at a stop light, cop was cool about it, but could have been an issue, at the very least a reason to stop him which is always good to avoid.
I planned to wire in a small surface mount led pilot light by the gauge cluster that will come on with the light bar to let me know when it’s on to avoid this. Similar to a high beam indicator. I had ordered 2 blue ones when I ordered my light bar but they sent me yellow the first time and had to return them to get the color correct. Once it warms up a little I will be adding it to my truck and will also be changing up the wiring on his so it can do the same.
Old Nov 30, 2021 | 08:25 PM
Lanc1969's Avatar
Lanc1969
Originally Posted by Poncho450
So in this scenario the high beams would not be in use on a highway? I can see these being blinding to oncoming drivers well before high beams alone would.
Remote area or late night/no other vehicles within a mile use I can understand. Other than that they'd just limit my high beam use for the most part.
why do people say stuff like this. Whaaaa the bright lights…! What a joke. Not everyone lives in the city and has constant oncoming vehicles. Some of us live away from the cry babies worrying about bright lights. Then there are folks out there driving with brights on constantly. Go cry to them.
Old Dec 1, 2021 | 06:25 AM
GNR22's Avatar
GNR22
I have a set of KC 6" Slimlite LEDs on my '21 that I have relayed into my brights, powered from upfitter 2. I had it just hooked to upfitter 2 with no additional trigger for awhile but I didn't like having to reach for it every time I met a car on the road. On my way to work at 4AM, I typically see a larger amount of deer than I see cars.
On my '21, I'm pretty sure the driver's side upper bulb high beam wire is white/blue.
Old Oct 27, 2022 | 09:01 AM
Lanc1969's Avatar
Lanc1969
Here is the high beam wire
After reading through the entire thread (and others) I still haven’t found anything showing me where the high beam wire is located on the headlight plug. Well, here is the passenger light plug. It’s 2nd from the end.
Scooter22
Nov 9, 2015 03:32 AM
Force21
Electrical Systems/Wiring
Aug 25, 2013 09:33 AM
Quick444
Nov 5, 2010 08:40 AM
Weezman
Sep 15, 2005 06:44 PM
Cooke V10
Modular V10 (6.8l)
23
Sep 11, 2005 06:32 PM
