View Poll Results: Which size wheel for a 37" tire
20x9 0 offset
50.00%
20x9 +18 offset
21.43%
18X9 +18 offset
25.00%
18x9 -12 offset
7.14%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
which wheel setup with 37" tires and a carli 2.5 pintop
I am thinking Nitto Ridge Grappler as it looks like it will be better in ice and snow just from the siping. Talked to CJC and one of the guys just took his truck up to the snow with the toyo's and said it slid all over... lots of factors that could cause this but its consistent with most peoples comments on the two tires.
Nitto Ridge grapplers: very good in snow, great on highway, low noise.
Toyo RT: good on highway, worked ok in the early snow this year.
Toyo AT/2: best on highway, best in snow, they do wear out fast though.
The last snowstorm we had, 10" at the house, 18" up high. I did not use 4x4 with the AT2 and got around fine.
I would have bought Ridge grapplers again, but they are challenging to get get here (Tahoe) and are much more expensive at the local shops.
my thoughts on tires.
Tire siping is key if you want winter traction. I was looking at the Nitto G2 & the Toyo AT2 because they have more sipes than the ridge grappler and the RT. The Nitto was $50 a tire cheaper so that what I went with. They also come in a 11.5” width in a E rated tire. So far I’m pleased with the way they handle in the snow. I did run into a bit a bad luck the other night though, but it’s not the tires fault. I must have run something over and it poked a nice hole in the sidewall of my RR tire! So I have a $300 tire with less than 2000 miles on it sitting in the junk tire pile now...
That is truly surprising we can fit a 38" with not much more than a 4" lift, but for my needs 2.5" is all I would really want to run. To think a few years ago 35" tires were large now that's the norm and 38-40 are the goal.
I did an 18x9 0 offset as I needed to clear my huge reservoirs at full lock and articulation. They stick out a tad in the front, are pretty much tucked in the rear. Super happy with the look and they dont throw much up on the truck when I'm bombing through the desert.
Fuel Mavericks:
Fuel Mavericks:
I tow a lot, so I didnt want to go too big. It also helps that these tires were $850 installed and the same in a 37" was about $1600...must've been a sale, but it was a no brainer for me.
#28
#30
As soon as my local guy gets back to me with pricing I'll pull the trigger unfortunately with all this time I keep thinking about it and now I have looked at the raceline defender, fuel vector, and the methods... in both 18" and 20".
