Blinkers not working
Old Jan 29, 2018 | 09:08 PM
Edward Michael's Avatar
Edward Michael
85 F350 Crewcab Longbed 460 4spdmanual 2wd
Has cruise control on blinker switch. Don’t know if it works.
New flasher in the fuse box.
Blinker arm turns off with steering wheel as it should.
Right blinker light in the dash is on always when the parking lamps and/or headlamps turned on.
We can get the blinkers to flash (very fast like rapid fire) when the arm is moved
around a bit. This happens easier on left than right. In fact right is very difficult
to get rapid fire!
Things to look for when we pull off steering wheel?
Old Jan 30, 2018 | 09:28 AM
FuzzFace2's Avatar
FuzzFace2
Do the 4 ways work and so you know it has its own flasher on the back side of the fuse box.
The light in the dash is a sign of a bad ground some where. I would check/clean all light grounds and test again.
I can't think of anything when you pull the wheel.
Dave - - - -
Old Jan 30, 2018 | 11:02 AM
madpogue's Avatar
madpogue
Do the brake lights work?
+1 on the ground; in particular, there's a wire that's grounded to the cab wall right by the parking brake pedal. Make sure that's secure.
Old Jan 30, 2018 | 09:04 PM
Edward Michael
4 ways are the hazards? Hazard lights working. All four. Head, brake and reverse all work.
Drivers front and fender parking lights are out. Removed bad bulbs and the right turn light doesn’t stay on now.
We tested the bad bulb sockets with good bulbs from working sockets and they checked out.
Have not found the ground by the parking brake pedal. Didn’t remove plastic on wall. Rusty screw holding it on and looks like it might turn into a lengthy project. Will start a new post for the e brake.
Summary is blinkers working at all sockets in rapid fire only. The blinker arm (with cruise control) on column must be tinkered with to get the blinkers to come on.
Any tips on fixing it before we pull the steering wheel?
texasweldingco
Feb 13, 2019 05:22 AM
justonv
Jul 15, 2015 04:39 PM
mike L
Electrical Systems/Wiring
Sep 14, 2014 06:56 PM
MCD46
Dec 12, 2013 03:01 PM
ItchSappinR1
Jan 10, 2006 09:08 PM
