My hazard, reverse instruments panel light don't work.
Old Sep 12, 2014 | 11:45 PM
mike L's Avatar
mike L
  • My hazard, reverse don't work. The over all instruments panel light doesn’t light up (the small bulbs work). Gauges with needles work.
Ok, so I'm putting every thing back into the truck. I left the steering wheel resting on the floor while cleaning and also left the wiring in. Everything else came out because I had to clean out the smell of mice. After I installed the instrument panel I started the truck, there was no hazard lights. I checked all the fuses under the dash. I checked all the fuses under the hood. I did have a bent brake plug blade to bend straight. I need to replace a bad key cylinder, you can turn it without a key. I believe there were three plugs I unplug to lower the steering wheel. Park brake, brake pedal and a plug under the steering wheel. Wipers, interior ceiling light work. I believe there's a switch on the column ( ? ) that includes the wiper arm. Should it also operate the hazard lights ? The steering column is installed, I can drive it around. Outside cargo lights won't go off, even with the light switch pushed in.
Everything worked before.
Old Sep 13, 2014 | 02:52 AM
mike L's Avatar
mike L
What does the brake switch on the brake control, reverse and brake light?
Old Sep 13, 2014 | 07:18 AM
Franklin2's Avatar
Franklin2
Brake switch on the brake pedal arm controls the brake lights. They also send a signal from this wire to the cruise control and the third brake light.
Old Sep 13, 2014 | 01:35 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you pulled the steering wheel WITH the clockspring attached you may have let the steering wheel spin breaking the clockspring..... Can't fix it, you may have to replace it.
Old Sep 13, 2014 | 10:35 PM
mike L's Avatar
mike L
No third brake light. So if I test the cruise control will that tell me if that brake switch is bad? Thanks
Old Sep 13, 2014 | 10:38 PM
mike L's Avatar
mike L
I laid down the steering wheel and column in one peice. Thanks
Old Sep 14, 2014 | 07:17 AM
Franklin2's Avatar
Franklin2
Go buy a cheap testlight and probe the switch. You should have power all the time on one side, and power on the other side only when you push the pedal down.
Old Sep 14, 2014 | 06:56 PM
mike L's Avatar
mike L
brake switch
No cruise control. Can I do a ohms test on that brake switch if so readings says its bad. Will probe the switch tonight. Thanks
Edward Michael
Jan 30, 2018 09:04 PM
mike L
Sep 12, 2014 11:20 PM
brian1080
Oct 18, 2012 11:24 PM
civiltech
Mar 28, 2011 12:39 AM
BSCowboy
Oct 10, 2009 12:46 PM
