Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Restoration project needs help
Old Jan 29, 2018 | 03:39 PM
burningair's Avatar
burningair
First off thanks for the add to the group and any help that could be given to the project.
I am a fireman with a long history of paint, body and mechanical experience going back 25 years. With that my local labor union and retires have ask if I could help getting one of the old department trucks back to "road worthy" status. Their hope is this truck will be used for our departments current and retired members final ride. As you may imagine, that request has pulled me into the project but I need help determining all the components so I can find parts.
Vin # F75WU400214
WB 174
Color J (red)
Model F756
Body 81A
Trans J
Axle H7E
What I could use is what you'd expect .... Engine size and carb.... Trans type..... Rear axle size and ratio?
Again any help would be great thanks!
Old Jan 29, 2018 | 05:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN: F75WU400214 / WB 174 / Color J / Model F756 / Body 81A / Trans J / Axle H7E / MAX GVW LBS 25500
F75 = F750 (gas).
W = 332 4V (Lincoln derived Y block).
U = Louisville KY Assembly Plant.
400214 = 1963, assembled April 1963.
174" Wheelbase.
J = Rangoon Red.
F756 = F750 (gas), 25,500 lbs. GVWR
81A = Standard Conventional Cab.
J = Clark model 250V 5 Speed Direct.
H7E:
H7 = Eaton model 17800 or 17801 Two Speed Rear Axle / 6.50/8.87 / 18,500 lbs. Rear Axle Capacity.
E = 7,000 lbs. Capacity Front Axle.
25,500 lbs. Gross Vehicle Weight Rating.
Old Jan 29, 2018 | 06:13 PM
burningair's Avatar
burningair
Thanks for all the information that is a huge head start.
Old Jan 29, 2018 | 07:42 PM
*2fords*'s Avatar
*2fords*
I do hope you can post pictures as you progress.
Prvtpyle
Large Truck
Jul 21, 2018 02:36 PM
TaylorDiabetoSwifty
Large Truck
Mar 20, 2017 12:51 PM
Auctioneer NJ
Oct 22, 2014 10:50 AM
Dodgedougak
Large Truck
Jan 9, 2014 10:49 AM
chaney71
Large Truck
Nov 2, 2012 08:47 AM
