Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C600 numbers
Old Jan 8, 2014 | 07:53 PM
Dodgedougak's Avatar
Dodgedougak
C600 numbers
Looking at a 1975 C600 with a flatbed towing body
Numbers are
C60EVX11490
WB 175 T 602 body 118 trans 2 axle F24
Build 5/75 front GAWR 6280 rear GAWR 11000 GVWR 17000
Looks like it has a 361 with a 2 sp rear end
Body looks good with only some bad repair around the passenger door mirror.
Can anyone decode trans and diff info? Thanks
Old Jan 9, 2014 | 12:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Dodgedougak
Looking at a 1975 C600 with a flatbed towing body.
VIN: C60EVX11490 // Warranty Plate: WB: 175 / COLOR: T / MODEL: 602 / BODY: 118 / TRANS: 2 / AXLE: F24 / MAX GVW LBS: 17000 / DSO: Omitted.
Safety Standard Certification Label: Production Date: 5/75 = May 1975 / front GAWR 6280 / rear GAWR 11000 / GVWR 17000
C60 = C600 Tilt Cab (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
X11490 = 1975.
175" Wheelbase.
T = Red.
602 = C600 Tilt Cab (gas), 17,000 lbs. GVWR
118: 11 = Light Grey Vinyl-Full Width Seat, C600/800 Tilt Cab / 8 = Standard Cab.
2 = Clark model 282V 5 Speed Direct.
F24: F2 = Eaton model 15201 Two Speed Rear Axle / 5.83/8.12 / 15,000 lbs. rear axle capacity // 4 = 7,000 lbs. capacity Ford front axle without P/S.
17,000 lbs. Gross Vehicle Weight Rating.
Old Jan 9, 2014 | 09:12 AM
Dodgedougak
Thanks
Thanks numberdummy! Great information
Old Jan 9, 2014 | 10:00 AM
NumberDummy
Where in AK are you located?
Old Jan 9, 2014 | 10:25 AM
Dodgedougak
C600
We are in Juneau, though I am currently traveling "down south".
Old Jan 9, 2014 | 10:49 AM
NumberDummy
I know a little bit about Juneau, been there 6 times on AK cruises. I've taken all the tours, visited all the museums and gun shops.
Most tourists are unaware of the memorial to the USS Juneau (CL-51) located on the dock. The cruise lines don't mention anything about it.
Prvtpyle
Large Truck
Jul 21, 2018 02:36 PM
OldClassB
Jun 22, 2017 08:47 PM
coyote1442
Large Truck
May 20, 2015 05:24 AM
Auctioneer NJ
Oct 22, 2014 10:50 AM
chaney71
Large Truck
Nov 2, 2012 08:47 AM
