1971 F350 lighting problem
Old Jan 29, 2018 | 02:23 PM
Josh_Musilek's Avatar
Josh_Musilek
Hello all, I'm new to the forum, but have read here for help before. I recently bought a 1971 F350 from a neighbor for a project truck and I have came across a lighting problem that really has me puzzled. The turn signal switch can be loosely moved between positions with no actual click of hold to it, but the real problem is what it actually is doing. The Left position works fine, but when it is turned to right turn position, then every light on the whole truck flashes as if it is a turn signal. I have a feeling it may be a ground that is disconnected but I have no clue. Side note, The steering wheel is rusted to the column and I can not remove it to get to the wiring there without likely destroying it.
Old Jan 29, 2018 | 02:32 PM
Brian1971f100's Avatar
Brian1971f100
Welcome to FTE first of all. Have you tried a steering wheel puller? I have never been able to remove the steering wheel without one. Good chance the problem is the turn signal switch.
Old Jan 29, 2018 | 02:55 PM
Thipdar's Avatar
Thipdar
When grounds go out, you usually lose lights; conversely, if you have lights, you have grounds.
I agree about checking the switch - what you've described makes me think there are broken parts inside the switch.
Old Jan 29, 2018 | 05:37 PM
Josh_Musilek
Thanks guys I will look into getting a steering wheel puller then. (probably shoulda' looked into that before a half hour of prying at it) I know I have a switch that worked at one time in the salvage so Ill swap that one in there and see if that fixes it.
Old Feb 2, 2018 | 12:20 PM
MainetoDC's Avatar
MainetoDC
Same thing happened on my '71 F100. In the end, pulled the steering wheel and changed the turn signal switch; problem solved. Steering wheel puller was key.
chris5301
1997 - 2003 F150
Oct 14, 2014 06:50 PM
toofazt
Sep 22, 2012 05:48 PM
86fn150
Feb 9, 2008 11:54 AM
larry p
Aug 30, 2004 10:49 PM
Gold Winger
1997 - 2003 F150
Jan 2, 2004 11:50 AM
