Engine is crooked
Old Jan 29, 2018 | 01:45 PM
Russ74's Avatar
Russ74
Engine is crooked
So I got my 445 stroker build finished. Everything buttoned up and it runs great! As I was putting the hood back on something caught my eye. The engine looks like it’s sitting crooked in the bay! As in the passenger side head is closer to the front of the truck than the driver’s side. I got my tape measure out and sure enough, that head is one inch closer to the grill than the other one. Anybody else run into this?
‘74 F100 390 (445 stroker)
C6 2wd
Old Jan 29, 2018 | 02:15 PM
HIO Silver's Avatar
HIO Silver
C6 2wd
Yup. the engine perches have elongated/slotted holes. Loosen them and rotate the engine until level... I used a jack with a 2x4 wedged against the pan rail.
EASY.
Old Jan 29, 2018 | 02:18 PM
JakeHan's Avatar
JakeHan
Heads on a V8 are always offset from each other a little, since the cylinders cant be square to each other because of the rod journals - if you're measuring from the head to the cowl (or to the grille), the motor might still be square.
Old Jan 29, 2018 | 02:23 PM
Russ74's Avatar
Russ74
That’s true. I’ll find I better place to measure.
Old Jan 29, 2018 | 02:25 PM
Russ74's Avatar
Russ74
EASY.
Ok. I knew they were slotted a bit going up and down. But didn’t notice them being slotted front to back. I’ll try that. Thanks. P
Old Jan 29, 2018 | 07:08 PM
somethingclever's Avatar
somethingclever
Opposing connecting rods cannot occupy the same space.
Old Jan 29, 2018 | 07:33 PM
flowney's Avatar
flowney
On dents and many others, the engine CL ≠ the frame CL. On dents, the engine CL is about an inch further to the passenger side. This makes for better alignment with the pinion of the rear axle.
Old Jan 29, 2018 | 08:31 PM
Russ74's Avatar
Russ74
Yep, I’ve looked at everything. It’s all lined up correctly. It’s in there like it’s supposed to be. Thanks for all the reply’s!
artscott61
Oct 22, 2015 10:59 AM
RustyTub
13
Nov 4, 2010 07:40 PM
71dusterjon
69
Apr 22, 2009 12:26 AM
IceWagon
May 5, 2005 01:06 PM
ajsmolik
Oct 15, 2004 02:47 PM
