flat head
Old Oct 21, 2015 | 10:20 PM
artscott61's Avatar
artscott61
Veteran: Navy
flat head
Have a chance to go look at and or buy a flat head v-8 the motor does turn over and has been covered in a 50 f-1 I will try to post some pic's. One head that I can see has 8CM on it. What would that be? Owner said that the carb has been covered. Can't give to much since it could be fried on the inside . With out pulling it down hate to offer much.
Old Oct 21, 2015 | 11:28 PM
52 Merc's Avatar
52 Merc
8CM is a Mercury head. Lets hope there's a matching pair. It could indicate it's a Mercury engine with the longer stroke crank. Or, it could be that someone thought putting Merc heads on their Ford 8BA would make it a hot rod. If so, the opposite would have happened since the Merc heads have larger combustion chambers which would lower compression, and power, on a Ford engine. There's no way to know what's inside without pulling a head and measuring the stroke. Good luck with your quest.
Old Oct 22, 2015 | 10:43 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I wouldn't give more than $100 for that engine and trans. Don't feel bad if it turns out to be money down the drain. You'd be much better off paying $600+ for an engine that is in running condition but pulled for the inevitable SBC changeover.
Old Oct 22, 2015 | 10:59 AM
artscott61's Avatar
artscott61
Veteran: Navy
Ross I am with you on the price I was not going to offer much since I can not see whats inside. Thanks for the reply.
Ken(Ark)
Flathead V8 & Flathead 6
Jun 9, 2012 10:30 AM
MR GOODWRENCH
Jul 4, 2004 04:18 AM
Mike67
Sep 22, 2003 03:51 PM
dfwscotty
Aug 30, 2000 06:32 AM
