Spring width
Old Jan 28, 2018 | 10:12 PM
46fordtruck's Avatar
46fordtruck
Spring width
I'm sure you all here can help with this. I have a 9" out of a '59 F100 for my '46. I have the '59 spring plates for attaching the U-bolts, thanks to willowbilly for those. Here's my concern, the '46 spring is 2" wide, the '59 had 2¼" wide springs. Will this be an issue, having the original springs ¼" narrower? Not sure if the springs in the U-bolts help control lateral rear movement.
Old Jan 29, 2018 | 12:50 AM
catimann's Avatar
catimann
Couldn't one just stuff a ¼" plate between and call it a day? It's not like you are going to use it for commercial purposes.
Old Jan 29, 2018 | 08:46 AM
willowbilly3's Avatar
willowbilly3
You should be fine. The spring center bolt is what locates everything.
Old Jan 29, 2018 | 08:50 AM
tinman52's Avatar
tinman52
Welder User
Yup, it'll work fine.......once everything is clamped together it can't go anywhere.
I have had the same setup on my F-1 for years.
Old Jan 29, 2018 | 08:59 AM
46fordtruck
Great, thanks guys, that's what I was hoping to hear. Not like I'm going to be autocrossing the truck. And it might still be required to do some hauling now and then.
jimcar-9
Oct 31, 2014 12:36 PM
Rocketman55
23
Aug 29, 2009 10:16 PM
Dustin_86
Dec 2, 2004 09:37 PM
OilLeaks
Mar 15, 2004 08:14 PM
oft
Dec 24, 2003 03:44 PM
