Sponsored by: Real Truck
Headlight bulb replacement
Old Jan 28, 2018 | 06:06 PM
Lawnpro979's Avatar
Lawnpro979
replced the bulb in my 2000 SD
Then noticed it was aimed pretty higher than the other one.
Im wondering if a person can put it in upside down or does it just need adjusting?
it was adjusted just fine before the bulb went out.
did I do something wrong?
thanks
Old Jan 29, 2018 | 02:45 PM
brian42's Avatar
brian42
Veteran: Navy
It should just need adjusting. The bulb does not have a specific alignment direction. As long as the socket fits in the housing and locks your bulb is installed. The housing takes care of the beam pattern.
IndySilverAnny
1997 - 2003 F150
Jan 31, 2019 12:53 PM
AKHunter93
Nov 21, 2015 11:35 PM
cwh82
May 29, 2004 11:48 AM
Goble18
1978 - 1996 Big Bronco
Feb 3, 2004 02:50 PM
