Pulling with an Ex...
https://www.facebook.com/MaximumAttackMotorsports/
Trip from NJ to Austin then to New Orleans was mostly uneventful. Truck pulls GREAT with the DP tuner, trans temps never above 155 in current weather (6L cooler). Brakes are incredible, mostly due to the three axles. We put it across the scales and that trailer is right around 15,000 pounds, all 34' off it.
Swaying was a bit troublesome around trucks. Typical Excursion assy-ness. Rear Helwig, rear airbags, HD Roadmaster, load bars and friction anti-sway and it was still a constant sawing back and forth. We think it's the 16" wheels and tires? That's really all that's left.
We left the rig down there and will be coming home after a race in New Orleans next month. I found some 20" wheels and 10-ply "E" tire take-offs from a 2017 F-250 down there, bought 'em and will be shipping down wheel spacers to try for the drive home.
Thing pulls dang nice, though.
That giant trailer most likely has more tongue weight than the 1400lb rating of both the Pro-Pride and Hensley Arrow. My 41' TT has 1480lbs of TW with an 11,300lb trailer weight.
"Cumbersome"? How so? I think that my Hensley is easier to hook up and deal with than my old trunion style WD hitch, no messing with mounting spring bars and super simple tensioning of the bars.
The swaying is aerodynamic. If we're cruising down the highway solo, we can run it at 70mph no problem, no swaying, changing lanes, curves, whatever. But if you see a truck coming in the rear view mirror it's time to ride: about midway up the trailer the front of the trailer gets pushed right so the nose of the Excursion goes left and you're steering right, then it flattens, then it goes the other way and you're steering left. Once the truck passes and you correct it causes a yawing oscillation that's easy for the driver to get behind (pilot induced oscillations).
Edit: BTW, for reference I have a similar swaying prob pulling my 28' 10k trailer, and my buddy that owns this 34-foot trailer loaded the same way says it is rock solid behind his Chevy dually. Unfortunately, that Chevy is his work truck so we couldn't leave it down there for the three month duration of this tour.
I got my two buddies riding with me to rock sideways on the quarter panel of the Excursion as we sat at the fuel pumps, and the two guys were easily able to move the *** of the truck sideways six inches. You can really see the tire sidewall flex. That truck just doesn't have the lateral stability of, for instance, a dually.
Wheels/tires may not be the perfect answer, but if nothing else it gives me a fine "safety" excuse to my wife for better-looking wheels...
We'll see how it works out in March when we go down to New Orleans.Any references for decent 2" steel spacers for those 2017 F-250 wheels? I'm aware of WheelAdapter.com but they're pretty proud of those. Also see I can get steel from Stahl's Steel.
Had it this summer with 35' camper behind our Excursion.
Be very aware of underpasses, too- especially when on flat open ground with some wind, then a rising bank/wind block on both sides for the other road to rise up and cross over.
I didn't have a sway bar, which I'll be adding. Ran out of time in this new setup for drilling and mounting, etc.
What is the Excursion hitch rating for all that tongue and trailer weight? I've heard of some replacing it with a different hitch, but not much about it- could have been damaged hitches, too?
Those 3 trailer axles look to be positioned to take a lot of the weight, which should help a lot. But makes the Excursion look tiny. We had the same thoughts when we hooked up our camper. The Ex always looked huge before hitching up
If your WD bars are curved on the back ends, you can move to a dual cam setup pretty cheaply. Mounting them on the tongue does require some drilling, but I suspect you have the tools on board to do that.
I find now that the whole rig moves side to side, as one solid unit, in the lane when passing a truck, but the wiggle isn't too bad. If I haven't pulled in a while, it takes some getting used to, but after a couple hours, I'm back in the groove and planning ahead for it. It might be due to tire sidewall flex, I'm not sure. I'm running stock size 265 Michelins with factory rear axle sway bar.
This brings up a good question- what are your tire pressures at? I would say for hauling that kind of tongue weight, I wouldn't have them any less than 70.
I'm using the stock Class IV hitch. Technically only rated to 10k. Edit: Just looked it up: Class IV good for 14k/1400 when using weight-distributing.
I run a Reese dual-cam on my 24-footer, and I still get sway. Not as bad as this big sail, though...don't recall if Ed's hitch and load bars are curved...
I believe the factory hitch is only rated for 1200 lbs tongue weight. Bent the receiver tube on mine with 1700 lbs of tongue weight, so I don't trust them for a lot of weight.
Ford 8-Lug Wheel Adapters
