97 F250 or 2003 F150 - which would you buy?
I've been looking at what I would call a creme puff 1997 F250 gas extended cab with 159k miles. One owner, records, garaged... I can get it for about 5k. Looking at later models I see the F150's can tow approximately the same weight. I'll hardly be towing with it and when I do it would be a 4000 lb boat. I may on occasion need to tow my backhoe that weighs about 8000 lbs for about 60 miles. I really like the 97 but logic tells me I should look at newer f150's if they cost about the same and tow about the same. Am I thinking correctly here or is there something I am missing about the 97 F250?
Oops... I just realized my thread title was incorrect. I'm talking about a 97 f250 vs 2003 F150. Considering they both tow the same amount I can get a newer f150 that tows as much as an older F250. Any advantage to having the older F250? As I am sure all are aware if it says 250 the price goes up. Of course the cam phaser issue is a concern for me on some mid 2000's..
Not sure when Ford want to the 3v 5.4, they were problematic, you haven't mentioned mileage on either truck. If the 03' has HD tow package, you are correct, similar tow ratings.
If the 03' checks out with appearance and all the fluids look good, check the front end, like tie rods and leaks while you're under there.
If it meets your criteria make your move.
Another plus is four doors, very handy.
Good luck,
Mickey
Good luck,
Mickey
![Okay!](images/smilies2/thumb.gif)
![Drink to That](images/smilies2/party0005.gif)
Stewart
Thanks for the replies! I have waffled...I now want a 99-2003 7.3 or possibly a good deal V10. I found out the backhoe I need to tow weighs about 11,000 pounds so I want to have enough capacity to handle occasional towing of heavy equipment to my lake property. I originally thought the backhoe weighted about 8,000 pounds. Now to decide the value proposition of a diesel vs. V10...spend less up front, gas vs. diesel cost, fuel economy. Probably a question for the SD forum. Unless any of you guys have some insight? Thanks!
However, based on the bit of info you've posted, I'd say go with the gasser. That opinion is based solely on how much the purchase price of a gasser is versus a diesel, and as well, the maintenance of a gasser when compared to a diesel.
Me? I just prefer a diesel, that's why I have them. I love to hop 'em up and make 'em fly.
Stewart
Stewart, thanks for the reply. Since you mention you have diesel, I am actually going to look at a 2001 F250 4x4 extended cab with 250k miles tomorrow. New Transmission with HD kit and cooler, glow plugs and injectors at 175K, new tires. Looks good and has service records, he wants 10K or best offer. I think it sounds like a good deal, maybe offer him 9K and go from there. Any advice? Thanks
Post up in the 7.3L PSD section that you're gonna go look at the truck and the guys there will give you excellent advice on what to look for and why. They'll also be able to get more info from you so a halfway decent price can be guessed at.
Stewart
