Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
SYNC
Old Jan 27, 2018 | 06:40 AM
sailorman3's Avatar
sailorman3
SYNC
My SUV doesn’t have SYNC but I have a radio out of anther Escape that does have it. Is it just a matter of installing it or does anything have to be programmed. Thanks.
Old Jan 27, 2018 | 06:46 AM
G Ford Fan's Avatar
G Ford Fan
I dont have a definitive answer for you, but i believe its more than just the radio. Sync vehicles have buttons on the steering wheel for the sync, at least my 08 focus does.
I'm not 100% sure on that though, but again i suspect it's more than just s radio swap. .
Old Jan 27, 2018 | 06:50 AM
sailorman3's Avatar
sailorman3
Ok thanks. Just trying to get all I can out of this junked Escape before I have it crushed.
Old Jan 27, 2018 | 07:56 AM
got2bjoester's Avatar
got2bjoester
I'm going to shoot from the hip here as well, but I think you need the satellite antenna too depending on the version/options of the radio. Some SYNC radios offer turn by turn directions and I believe that requires the satellite connection.
If you take everything connected to the radio, logic says you have your bases covered.
Old Jan 27, 2018 | 08:06 AM
sailorman3's Avatar
sailorman3
Yes thanks I have the sat antenna already. I’m stripping the truck anyway. I’ll have all the parts. Weather I want to put them all in is another story.
Old Jan 28, 2018 | 05:48 AM
got2bjoester
I was just recalling an issue I had when I got our current Escape -
The previous owner had not de-registered and I had to call SYNC from the vehicle so they could get things straightened out. One of the things they required was the VIN. You may want to make sure you have the donor VIN available when you install it.
Old Feb 5, 2018 | 03:29 PM
etbland's Avatar
etbland
Yes, you WILL need the VIN of the old Escape--The Sync module is located (2008-2012 Escape) inside the center console, next to your right foot (it is called the APIM ). Here is a kit that Ford sells to add Sync to 2009 Escapes (just for visual reference) Ford Sync Kit Get the APIM and harness, there are microphones in the top of the rear-view mirror, (you could add your own) and the USB and Aux audio ports in the middle of the dash. If you have the radio and Sync from the same Escape, you should not need programming (I think)
HTH
artscott61
Oct 31, 2017 08:50 AM
swimmer_spe
2009 - 2014 F150
Nov 21, 2015 03:11 AM
LEANNMEAN
May 29, 2015 09:03 AM
porkysnow
6.7L Power Stroke Diesel
May 5, 2011 08:18 PM
kailor
18
Nov 10, 2007 11:10 PM
