55 F250 Axle swap direct fit
I have been seriously considering upgrading my Dana 60 with 4.88 gears to something I can get 60 mph out of. I have a strong desire to travel to Truckstock and other locations that 48 mph just makes difficult.
Since I don't have welding skills, I want to find a direct bolt in. My carrier will only go to 4.10 and that won't get me the speed I'm looking for. I think a Dana 60 with 3.73 should get me.
I have heard that 57-72 8 bolt Dana 60 is a direct fit, but I have also heard that 68-72 is the only direct fit. So, before I spend money for the wrong part, what should I be looking for?
I need to keep it 8 bolt lugs, and would prefer to stay with a Dana 60. I'm a stocker, but I also have the farmer mentality of making what you have on hand work to get the job done. The path to the darkside is a slippery slope, I must avoid the cookies.
The guy just disappeared. The the ad was gone. I can only guess that he sold it to someone else. Yep, speedo gear won't be a big deal. My dad had a 54 Chevy that he just had to know what 55 was on the gauge. Not sure how he did that back then. But today it is easy with our phones.
Yes, it should be an easy change. Cleaning up the new one will be the biggest chore. Well, after I find one.
I went to here to check values: RPM/MPH From Gear Ratio Calculator by Wallace Racing
With my 31" tires and 1 to 1 transmission ratio in 4th. I get this:
So by this, my ear seems to think about 2500 rpms are comfortable. I need to break down and buy that 6v tach. Westach sells them.
How tall are your tires? Do you have overdrive?
Hard way or easy way ? Just slide a midship auxillary with OD- Direct and under. Little
drive shaft work you will be glad you did. They are out there just gotta look for them. Prime
example my main trans has overdrive my and my auxillary has overdrive. About oh
around 50mph put main in od. run her up to about 2800 rpm put aux in OD; now just
too fast for old bones and eyes..... lol : America ya just gotta slow down "55 saves fuel and
lives" What you don't know is it takes about 20min for us to dig your vault an lower you in.
I think at 60mph it was 3500rpms..... not positive, though. In my 6 hour trip on Tuesday it did not over heat at all.
