Rear Brake Line ruptured
coming home last night I stepped on the brake pretty hard and then the pedal went soft.
turns out the hard brake line going to the rear above the rear axle is now leaking. The rupture appears to be in the hard line just rear of the fuel tank about 4 inches before it threads into the flex line.
the brake line runs inside the frame all the way to the front of the truck as one line and is tucked in behind the fuel tank.. How do you replace this brake line? Do you need to remove the fuel tank to do this? does the replacement line come as a two piece or is it still a one piece line?
Help...
Help...
What I did was cut the line as far up toward the engine bay at a point where it was easy to access and the material was good.
Bought the proper length of line and connected it there after running it along the frame first and making the necessary bends.
I left the old line in place and just wire tied it as I went.
Keep in mind if your using just a piece of stock without pre flared fittings you will need a double flaring tool to make it right. It's pretty simple and straight forward.
Denny
Denny
What a PITA job...
There was a pinhole size rupture on the backside of the line near the rear.
I got by with only unbolting the front strap on the fuel tank. Had to cut the old line to get it out.
use the following sized new line to replace: 1 x 72", 1 x 60", and 1 x 40". in that order from back to front. The front one could have been shorter like maybe a 30". And you need the unions to hook them together. I replaced the union all the way at the front as well cuz it was uber rusty...
MS86
1999 to 2016 Super Duty
03-28-2017 05:12 AM
whalerron
10-19-2014 09:42 PM
Scottay
04-28-2010 09:13 PM
