Brake line help
Old Jun 30, 2015 | 02:04 PM
rider300's Avatar
rider300
Brake line help
Did anybody replace the brake line that located in the left frame from about the fuel filter to the back? Do I need to drop the tank or just try to run it through ? The old line is still there, I couldn't pull it out all ....thanks
Old Jun 30, 2015 | 10:25 PM
jimbbski's Avatar
jimbbski
Easiest way is to just run new line from where you can access the line bypassing the part that's hidden via an alternate routing.
Old Jul 1, 2015 | 01:36 PM
rider300's Avatar
rider300
Thank you, I will just run next to it, I guess no need to start digging out the old one. I just thought I would of use the old clips if I could get to them.
Old Jul 8, 2015 | 07:42 PM
blageurt's Avatar
blageurt
Just use plastic tye wraps and attach the new line to what is left of the old one....
Old Jul 9, 2015 | 06:38 AM
JWA's Avatar
JWA
100% fully agree just running new lines next to old, use the plastic coated tubing if possible---its an improvement over the bare unprotected steel stuff.
My '03 blew this same line and instead of fishing all the old out from behind the fuel tank I ran the new in one length, securing it with cable ties as already mentioned. Been over a year and all is still doing great.
Old Jul 9, 2015 | 12:31 PM
AAubinoe's Avatar
AAubinoe
We just finished doing all new brake lines on my friends 1997 F150, which has a similar gas tank I think. We pulled all of the old lines out. The thing had 2 line patches and was leaking at the rear wheel cylinder. In my opinion you should take a good look at the rest of the lines and rubber lines.
We replaced all 3 rubber soft lines and all of the hard lines with a stainless kit for inline tube for around $250.
Old Jul 9, 2015 | 06:20 PM
annaleigh's Avatar
annaleigh
can you get brake lines from them for a e series van? They didnt list mine
Old Jul 9, 2015 | 11:58 PM
AAubinoe's Avatar
AAubinoe
Yes Id bet on it. They did not list a 1997 F150 either for some reason, called them up and they said no problem. Great customer service, and the lines fit perfect. Days work is definitely worth 10 years + piece of mind!
afonda
Jan 29, 2018 08:10 PM
MS86
Mar 28, 2017 05:12 AM
bstarz40
Nov 23, 2012 05:35 PM
pace car
Sep 30, 2012 04:11 PM
brimis
May 16, 2012 10:06 AM
