Taillight wire sheathing
Old Jan 24, 2018 | 09:42 PM
mOROTBREATH's Avatar
mOROTBREATH
My tail lights had a shrink wrap type rubber thing around the bulb socket and wires as they exit the bulb socket. This wrap is almost obliterated and I am really trying to avoid paying $90 for replacement fixtures that are new just for this one little problem.
Anybody have any ideas on what type of material I could use that would actually stand up to the sun and weather? Heat shrink is really not meant for extended/constant UV presence.
Not to mention, there really doesn't appear to be a heat shrink material that starts out large enough diameter to cover the bulb socket, but shrink small enough to house only three 16-gauge wires....
Thanks for any help.
Old Jan 24, 2018 | 09:49 PM
abe's Avatar
abe
Try this asphalt impregnated wire loom. This one on eBay is sold by the foot in various diameters.
https://www.ebay.com/itm/3-8-x-10-AS...53.m1438.l2649
Edit: oops this auction is sold by the 10' length.
Old Jan 24, 2018 | 09:53 PM
abe's Avatar
abe
Here is a picture from the eBay ad.
Old Jan 24, 2018 | 10:03 PM
Mixer man's Avatar
Mixer man
Heavy walled marine grade heat shrink tubing will work just fine for that. It even has waterproof adhesive goo inside. I have used RTV and shrinked over it. Works great.
https://buyheatshrink.com/heatshrinktubing/
Old Jan 24, 2018 | 11:27 PM
matthewq4b's Avatar
matthewq4b
Ultra-high shrink, heat shrink tubing will do the job. Heat shrink is available up a 8:1 shrink ratio, a 1" ID tubing at a 8:1 sharing ratio will shrink down to 0.125"or 1/8" ID but you are not going to buy it from your local auto parts store.
You need something like Raychems HRHT (High Ratio Heat-Shrink Tubing) It comes in a 19MM ID unshrunk /3MM ID shrunk. That should do the trick for ya.
Old Jan 25, 2018 | 12:13 AM
mOROTBREATH
Wow thanks ya'll, had no idea any of that stuff existed!
jamburgey25
May 3, 2017 09:12 PM
SixGunCaliforniaKid
18
Jul 21, 2015 11:26 PM
rcbsr7
Oct 3, 2012 08:03 AM
EXv10
May 15, 2009 07:28 PM
