Oil cooler...
Old Jan 24, 2018 | 09:34 PM
afonda's Avatar
afonda
Oil cooler...
I meant to share these photos from last year when I had my overheat issue. That junk is gasket material from the thermostat. The thermostat was bare when I took it out. The diesel in the coolant broke down the gasket material and plugged up the oil cooler causing the oil to overheat and thus the engine to overheat when working hard like pulling hills and towing.
enjoy...
Old Jan 25, 2018 | 08:17 AM
Arizona97's Avatar
Arizona97
That is ugly!! I hope I don't see that when I break down my old Oil Cooler that I just replaced. What did you use to clean the cooling system?
Ed
Old Jan 25, 2018 | 09:05 AM
JayTheCPA's Avatar
JayTheCPA
Am thinking it is time for a regular diet of oil analysis?
Old Jan 25, 2018 | 09:56 AM
afonda's Avatar
afonda
Ed
flushed with about 20 gals of distilled water.. 3 or 4 flushes it took. diesel is nasty stuff when it gets in the wrong places...
Thank god for the injector cups to block all that junk... can you imagine that stuff getting in your injectors???
Old Jan 25, 2018 | 10:38 AM
Arizona97's Avatar
Arizona97
afonda, no it would not be good to the injectors. I know that Anthony at SD Service uses diesel fuel to flush out the system when there is diesel or oil in the coolant, I can't imagine him leaving it in for very long, and then how to dispose of it........
Also Dieseltechron RIP has a video of how he cleans out a contaminated system
Ed
Old Jan 25, 2018 | 11:08 PM
retiredsparky's Avatar
retiredsparky
It is unfortunate that Ford doesn't have an extended mileage maintenance schedule in the manuals. Replacing injector o-rings and oil cooler o-rings would probably be on that list at about 200K miles/? years and rebuilding the fuel bowl. Oh, why not just do all the o-rings at 200K?
Tdracer344
Jan 3, 2017 08:07 PM
Gvnam
Jun 6, 2016 09:41 PM
vtown00
21
Feb 12, 2015 08:13 PM
Enduroman
Sep 22, 2013 08:44 AM
benbe71
15
Jun 9, 2010 01:07 PM
