e40d problems after rebuild
Old Jan 24, 2018 | 07:09 PM
quint73's Avatar
quint73
Odd problem. Rebuilt the trans in my sons 1994 f250 460. Initial test drive went really good. Went through all gears for 20 minutes with out bouncing our heads off the back window. We decide to push the OD button to off. The truck down shifts kind of hard after the button is pushed. 10 minutes later we stop at a red light seems like it is either slipping or is trying to start off in a higher gear. There are no codes. Takes about 3/4 throttle to get it moving. Any help would be appreciated. I have been searching this site for 3 days now as a guest and decided to register and start a thread.
Old Jan 24, 2018 | 07:40 PM
rla2005's Avatar
rla2005
Originally Posted by quint73
There are no codes.
Thanks for joining!
Please define your statement "no codes". At the very least you should have gotten the System Pass Code 111 for KOEO and if no stored codes then 111 again. Anything less means you did not perform the tests correctly, poor contacts with the data link connector or you have a bad computer.
Old Jan 24, 2018 | 07:58 PM
Briansshop's Avatar
Briansshop
Did you build the trans? What happens in m1,m2 and R gears?
Old Jan 24, 2018 | 08:27 PM
quint73's Avatar
quint73
sorry i got 111 use to another forum that they tease you for saying that.
manually 1 and 2 are better but takes quite a bit of pedal maybe 1/4 throttle. reverse grabs like it should. I was going to do all the updates but it had them in it already. just replaced clutches and steels new TC,seals orings,thrust washers and bearings. fluid and filter.
Old Jan 25, 2018 | 08:16 PM
quint73's Avatar
quint73
bought a new transmission today and installed it new one works as it should.
rjrandy96
Feb 6, 2016 08:13 AM
coreyw2
Dec 5, 2015 04:52 AM
4_whl_hvn
May 10, 2015 09:16 AM
DamnFord
Jan 10, 2014 10:35 AM
DesertStorm
15
Nov 1, 2011 10:03 PM
