Electrical Gremlin 97 Expy...help!
Old Jan 24, 2018 | 06:28 AM
97EBExpy's Avatar
97EBExpy
got a weird one for y'all...parked fine last night...this morning, omw to work...driver window and rear wiper won't work. when i put it in neutral, everything works, back into drive OD off light flashes, A4WD 4WD hi and low all flash at once, window again won't roll down. it will however roll up...tried again..same thing..neutral works ok...back in drive no window..(only the drivers window btw)
....any clues?? I'm just lost on this one...any help appreciated
also forgot to mention, PDL aren't working now...at the door nor on the remote (alarm does arm though)
Old Jan 25, 2018 | 01:39 PM
alloro's Avatar
alloro
Did it rain overnight where you are or did you go through a car wash?
Old Jan 26, 2018 | 06:28 AM
97EBExpy's Avatar
97EBExpy
yes, been snowy/drizzle and i did was it a few days before
Old Jan 26, 2018 | 08:11 AM
alloro's Avatar
alloro
On your year water leaks through the corner of the windshield and drips into the GEM mounted to the back of the fuse box under the dash. This causes all sorts of electrical issues.
Old Jan 26, 2018 | 11:00 AM
97EBExpy's Avatar
97EBExpy
Is there a fix?
Old Jan 27, 2018 | 06:04 AM
projectSHO89's Avatar
projectSHO89
Originally Posted by 97EBExpy
Is there a fix?
Of course there is.
1. Fix the leak.
2. Repair any damage caused by the leak.
Old Jan 28, 2018 | 11:19 AM
alloro's Avatar
alloro
Is there a fix?
The only correct way is for the windshield to come out and be resealed. Talk to a local auto glass company about it.
teamlx88
May 21, 2015 08:30 AM
anothen
1997 - 2003 F150
Jun 26, 2009 06:15 PM
Curt Bates
May 29, 2009 12:09 PM
Crossett
1997 - 2003 F150
Mar 20, 2003 07:54 PM
