new seats!
Old Jan 28, 2018 | 12:38 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The wires in the 3rd picture are the power input to the whole system. They are the correct ones. If you did not have success after hooking them up, there is a problem somewhere with the seat circuitry/electronics OR the fuse is blown.
Do you have 12V to the dark green wire on the driver's side? Is the ground good (black wire)?
Old Jan 28, 2018 | 10:52 PM
mastiff23's Avatar
mastiff23
So i put my original seat back in and hooked it up and it works,fuses are good also.Green wire is hot.I'm wondering if it's the seat motor itself.
Dumb question but if I hook a car battery directly to those two wires on the seat shouldn't it work?
Old Jan 29, 2018 | 12:50 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes it will work, but with no fuse you better hope that seat motor isn't defective.
That seat has an electronics package attached to the underside of it. If anything is wrong inside that box, the seat might not work. That may be what you are dealing with, or the seat motor might be no good.
You could always attach that seat to your old frame. It should work out OK.
Old Jan 30, 2018 | 10:15 PM
mastiff23's Avatar
mastiff23
So I took the original harness off and put the other seat harness in and what do you know she works!!
Old Jan 30, 2018 | 10:17 PM
mastiff23's Avatar
mastiff23
Still have to wire the power point in the center console and then a good leather cleaner/conditioner and she's good to go!Big thanks to NICMIKE for all your help!
Old Jan 30, 2018 | 10:31 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Happy to help and congrats!
bbm10244
Oct 8, 2016 04:25 PM
JonathanN
13
May 8, 2012 09:57 PM
86f1504x4Extended
Feb 8, 2009 06:13 PM
caffine2003
Dec 18, 2005 10:10 PM
Toreador_Diesel
Dec 19, 2004 06:36 PM
