cataclean
Old Jan 23, 2018 | 05:54 PM
spooktn's Avatar
spooktn
cataclean
As an ASE Certified tech myself, I never had any faith in anything that is dumped in the gas tank that claims it repairs catalytic converters (or anything else, for that matter). Understanding the fuel injection system as I do, as well as the ultra high combustion chamber temps and the incinerating heat of the converter itself, I knew nothing could survive such ungodly heat and molecular transformation to "clean out" the fuel system or the exhaust system, much less the catalytic converter itself!
But faced with a PO420 code myself and determining the problem was indeed my cat, I reasoned that a $25.00 investment was worth a shot.
I bought a bottle and dumped it in my tank at 1/4 full as the instructions say. I drove the 15 miles and then refueled. I reset my CEL and drove for over 100 miles with the light staying off. However, when I scanned it again, it still had a "pending" PO420 code even though light was off.
20 miles later, the light came on again so I was about to chalk Cataclean up as a big hoax. But upon reading more reviews, I found that some success stories stated that they acheived success only after buying a 2nd bottle and trying again. So I decided to give it a 2nd try.
This time I let the fuel tank go slightly below the suggested 1/4 tank and I poured the 2nd bottle in the tank. Instead of just a slow, normal 15-20 mile drive I went out on the Interstate and punched the throttle wide open to over 5k RPM for about a half mile. Then I slowed down and did it again, and yet again. All 3 times black exhaust streamed out the tail pipe. Then I just ran it steady at about 70 mph til the tank was almost empty.
I refueled with Sunoco 93 Octane because I thoiught it could only help the cause. I then reset the light, drove another 100 miles, and then did another scan. This time the "pending PO420" code was gone and the "codes" list was empty, stating "NO CODES".
I have driven over 1,000 miles since and still no light and no codes! So I can personally attest that Cataclean is an authentic winner! My advice to anyone is to drive it longer than 15-20 miles and don't be afraid to punch the throttle to "blow out" the carbon while the Cataclean is doing it's thing. It really did work for me doing it that way. Good luck to all! After reading this I wondered if this guy sells cataclean or if it really works,,,hope everyone will post comments on cataclean or a even better product,,,,just testing the water before I buy something
Old Jan 24, 2018 | 11:38 AM
reddog99's Avatar
reddog99
I wonder if the code could have been cleared by only doing the WOT routine by itself without the product?
Old Jan 24, 2018 | 12:07 PM
Conanski's Avatar
Conanski
Yeah that was my thought.
Old Jan 24, 2018 | 02:30 PM
spooktn's Avatar
spooktn
HHMMM interesting idea,,I was having a EGR code pop up,,,,I put in a bottle of techron I think,,,or something like that,,,just to see if it would clear the code,,,my sister got my temper up and I did a jackrabbit take off after backing out of my drive ( my 3.0 or 3.slow some people call it ) smoked the right rear tire all the way threw first gear,,,I let up on it when I shifted to second,,, and no more code,,,,so was it the product or the jackrabbit takeoff ????? I have saw a lot of Pawpaw post about using the product he uses and was just thinking of adding a bottle of something once or twice a year as preventive maintance to keep injectors clean and carbon buildup from happening.. Hope Pawpaw reads this and reminds me which product he uses
Old Jan 24, 2018 | 08:46 PM
Kruse's Avatar
Kruse
Not gonna look it up tonight...just been too long of a day.
BUT, didn't Scotty Kilmer do a video where you drop the catalytic converter and run soap through it, or some thing like that?
Old Jan 24, 2018 | 08:58 PM
spooktn's Avatar
spooktn
Saw a video by someone who drilled a small hole in exhaust pipe 1 inch in front of cat and sprayed in something in a can (cant remember what) made truck smoke bad while spraying,,,when done cat was clean smoke stopped and then welded hole shut
Old Jan 24, 2018 | 09:30 PM
LeoJr's Avatar
LeoJr
Yes he did. If adding lacquer thinner to the fuel doesn't lean it, he says to drop the cats and soak them in soapy water, like with dish washing soap.
We have two explorers with 5.0s that are constantly lighting the Check Engine indicator for a week and then it is dark for a month. Passing the annual inspection is a matter of timing.
jv2290
Jun 2, 2019 08:24 PM
2011expedition
Sep 3, 2018 10:17 PM
Fortworthian
Aug 14, 2018 02:30 PM
Slyhuntr
May 15, 2015 02:00 PM
