1978 - 1996 Big Bronco
Temp gauge
Old Jan 22, 2018 | 01:45 PM
Robertsma2's Avatar
Robertsma2
Temp gauge
Ive got a ‘92 5.0 - is it possible to replace the temp sending unitl for the stock gauge with an analog gauge? My temp gauge is vague at best and id like to install a basic, numbered coolant temp gauge as a replacement. From what ive read it seems like the ecu gets its info from another sensor...not the same as the gauge.
thanks!
Old Jan 22, 2018 | 04:09 PM
McLeod's Avatar
McLeod
Originally Posted by Robertsma2
Ive got a ‘92 5.0 - is it possible to replace the temp sending unitl for the stock gauge with an analog gauge? YES My temp gauge is vague at best and id like to install a basic, numbered coolant temp gauge as a replacement. You can do that From what ive read it seems like the ecu gets its info from another sensor...not the same as the gauge. The PCM uses the sensor at the TStat housing and your gauge use the one to the right of distributor
thanks!
See this link:
https://www.ford-trucks.com/forums/1...-location.html
Tcook911
Jul 23, 2014 10:01 PM
thordehr
May 7, 2012 04:39 PM
brelandt
Bronco II
Jul 13, 2006 09:03 PM
smitty7
Nov 12, 2003 02:56 PM
