00 f350 4x4 v10 no start
on
Check for power at key on at the inertia switch in the passenger kick panel.
There will only be power momentarily after the key is switched on so set up your meter so you can see it and turn the key at the same time or get someone to turn the key for you.
If you get 12V out of the inertia switch it is time to swap the fuel pump.
Unfortunately, Ford changed around the location of fuse panels and relay locations quite a bit between years and models. On some, the relay is behind the radio, to the left of the turn signal flasher module. On others, the relay is an integral part of the under dash fuse block and is not field replaceable.
As mentioned above, check the intertia switch behind the passenger side kick panel. Check for power before and after the switch. If there's no power going to the switch, then it points toward the relay. If there is power coming out of the switch, then it points toward the fuel pump.
Pixel123
05-29-2019 11:38 AM
MIKE861943
09-12-2017 08:51 AM
shadetree1980
08-27-2016 09:57 PM
Tbrooks09
04-17-2014 07:41 AM
BobcatSteve
01-20-2003 08:59 AM
