00 f350 4x4 v10 no start - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 01-21-2018, 10:36 AM
Ken Collins Ken Collins is offline
Ken Collins is starting off with a positive reputation.
truck has been sitting four six months cranks but has no fuel pressure fuses are good not sure where the fuel pump relay is any help
Old 01-21-2018, 01:40 PM
Sam I Am's Avatar
Sam I Am Sam I Am is offline
Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.
Check for power at key on at the inertia switch in the passenger kick panel.
There will only be power momentarily after the key is switched on so set up your meter so you can see it and turn the key at the same time or get someone to turn the key for you.
If you get 12V out of the inertia switch it is time to swap the fuel pump.
Old 01-22-2018, 08:13 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
smack the tank with a 2x4. Seriously. If the battery was dead and you tried to crank it, the brushes and commutator in the fuel pump may have arced and are not making contact.
Old 01-26-2018, 05:42 PM
maticuno's Avatar
maticuno maticuno is online now
maticuno is gaining momentum as a positive member of FTE.
Quote:
Unfortunately, Ford changed around the location of fuse panels and relay locations quite a bit between years and models. On some, the relay is behind the radio, to the left of the turn signal flasher module. On others, the relay is an integral part of the under dash fuse block and is not field replaceable.
As mentioned above, check the intertia switch behind the passenger side kick panel. Check for power before and after the switch. If there's no power going to the switch, then it points toward the relay. If there is power coming out of the switch, then it points toward the fuel pump.
Old 01-26-2018, 08:48 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
The 2000 has the serviceable relay behind the radio. Off the top of my head, it was 02 or 03 when they went to the non-serviceable (easily) relay in the CJB.
91 ford F150 wont start Leamon 1987 - 1996 F150 & Larger F-Series Trucks 4 06-28-2017 08:55 AM
metal fuel line mtman390 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 05-18-2017 08:51 PM
How can I increase fuel mileage in 02 5.4 Expedition rlewis581 1997-2006 Expedition & Navigator 14 04-27-2017 10:32 PM
6.7 vs 7.3 fuel system, and tier 4 final tractors. zeroo General Diesel Discussion 2 04-15-2017 06:12 PM
Fuel Pump Problem Solved MA Berlin 1987 - 1996 F150 & Larger F-Series Trucks 5 04-28-2016 01:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
