Sponsored by: Real Truck
Best 12V Horn without large compressor?
Old Jan 21, 2018 | 07:33 AM
RailDawg's Avatar
RailDawg
Want to get the loudest horn possible that sounds like a truck without having to install a large compressor.
Is a really good horn possible?
Thanks!
Old Jan 21, 2018 | 09:50 AM
alloro's Avatar
alloro
Try these: https://www.google.com/search?q=elec...w=1219&bih=732
Old Jan 21, 2018 | 12:34 PM
Projectlittleredf250's Avatar
Thanks!
What do you consider a large compressor?
I have a viair 444c mounted behind my rear seat of my extended cab with the tank mounted on the frame rail. Also bought hornblasters xl kit, I love both of them.
Old Jan 23, 2018 | 08:59 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
I have the Kleinn Air Horn SDKIT-734. My reason for choosing this was that they designed it to "bolt right in" on my '13 - they have a spot for the compressor/tank as well as the horns. Now I will warn you, there is "some assembly required" but if you follow the instructions you should be fine. An electrician I'm not, great at turning nuts and bolts. Once I had it installed I took it to a Boomer McLoud to have the wiring done. It's hooked up to upfitter switch 1. If the switch is on and I hit the horn - the air horn goes off, if the switch is off and I hit the horn, the normal horn blows. And it's loud, it's nickname is "the horn of death" cause it makes your heart jump.
Old Jan 27, 2018 | 12:41 AM
jesse24spd's Avatar
jesse24spd
Depending on what the laws in your state are you can run this.
https://www.google.com/shopping/prod...QpnDMIQ8wII0Qo
I know that in MA it is legal as long as there is no siren.
Old Jan 27, 2018 | 06:12 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
It's electric - that's excellent. Wish I would have known about that when I bought my Kleinn. I do kind of like that I have a compressor and air tank on board, I have helped a damsel in distress or 2 - a prince I'm not
FordmanShane
28
Dec 17, 2010 12:50 AM
atomicjoe23
Feb 20, 2009 09:33 PM
Unimog005
22
Dec 1, 2008 05:55 PM
CobraJay
Sep 10, 2007 01:37 PM
05f50
2004 - 2008 F150
Jun 23, 2006 04:02 PM
