getting ready to pick up a dump bed insert for my 2012 F-350 for firewood/light tree service work, and looking to add some air bags to manage the sag...who makes a good reliable set? Also, source of supply for upfitter switches, or should I just get OEM switches from the dealer. Thanks!
Put a firestone system on mine onboard compressor mounted under spare tire remote control. Five pounds when empty 50 when goose neck attached. So far so good
X2 on the Firestone’s. They also have great customer service if there is a problem. As far as the upfitters I would check out eBay. There are always one sets for sale some even brand new in the box.
Perfect...appreciate it! Question: do these systems have some sag sensor that automatically actuates the bags, or is it entirely manual? I had a Nissan Armada a couple years back that had factory bags, and it automatically activated based on the load.
Pretty sure it’s all manual. 10 psi is recommended minimum. You can buy a compressor kit with a tank that fills automatically when low that way you have air on demand if needed to pump them back up.
I see several different models of the firestone bags listed...2535, 2550, 2585, etc. recommendations? I’m going to be hauling firewood and wood chips mostly with a dump bed insert.
I like this load controller....it's a bit pricey, but I'm leaning towards it for the X (with firestone bags). They also make one that runs both at the same pressure instead of independent control. They also have light duty and heavy duty compressors, so you can get systems cheaper.
More than likely, different part numbers are for different fitment applications. My 2014 gas f250 used a different part number than my 2015 f250 diesel because the mounting brackets were a little different (to allow for the def tank). The Firestone bags really helped a lot, and I like their design better than similar products from air lift.
