Coolant leak
Old Jan 20, 2018 | 09:23 PM
countrysF250's Avatar
countrysF250
Coolant leak
1993 f350 460 has a coolant leak from the short hose that goes from water pump to intake doesn't leak when truck is run on a regular basis only when truck sits for a couple days. Replaced hose made no change any ideas would be appreciated
Old Jan 21, 2018 | 04:17 PM
Binkowski's Avatar
Binkowski
Well seeing that you live in Virginia you probably need those hoses going to the intake. Just replace those hoses. But if you have a bunch of corrosion and rust, you could cap those fittings off and not have to deal with it anymore. It's meant to help the intake not freeze when it's cold. Your call.
Old Jan 21, 2018 | 04:38 PM
ChRoNo16's Avatar
ChRoNo16
I would NOT cap them, VA can get cold from time to time and that could be an issue
Old Jan 21, 2018 | 07:51 PM
joey2fords's Avatar
joey2fords
two things come to mind ...
1. smooth out the mating surface of the spigots with sandpaper.
2. if you are re-using some sort of factory spring-clamps get rid of them and use screw-type hose clamps.
bizzelj
Dec 13, 2015 09:09 PM
jwylie2125
Nov 26, 2012 04:53 PM
jrank
Oct 4, 2010 05:54 PM
ChurchBuilder
Jun 26, 2007 12:35 AM
GFDHoytJr
Apr 22, 2004 03:10 PM
