Injector time?
I have a lot going on in this thread so bear with me... trying to be thorough and make the right choice before dropping another $2500-3000 on this POS.
I've got a 2000 F250 7.3 w/ZF6, it is modified a bit and should be all set up and ready for bigger injectors...
GTP38R
HPX
FRX
S&B intake
MBPR 4" turbo-back
EBPV delete
Gearhead tunes on a T&S cheap-chip
South Bend 400 HP clutch
Random, semi-related facts;
- #1 I want this thing reliable and running strong for another 180k miles.
- #2 The truck needs to pass emissions in Denver. It's a particulate count only test.
- #3 I don't tow much... maybe a light load twice a year... like 5k lbs on a trailer. However, I do plan to carry a truck camper on long trips in the future
- #4 As currently set up, I have never seen EGTs over 1100F or boost over 25 PSI, even going up "the pass" on I-70 at 80 MPH
- #5 I hate black smoke and want it running clean
- #6 I'd like to make as much power as reliably possible (400 WHP seems attainable but not priority) - not opposed to doing the HPOP as well but it doesn't seem to have any issues currently
The problem; It starts like *** anytime it's below 40F. At 20F or less it's got to be plugged in or it won't even attempt to fire. When it does fire, it runs like *** for about 15 minutes or until it's warm. From what I understand from research, these are two separate issues. When it is really cold I typically run the glow plugs through one full cycle, I do not rely on the "wait to start" light so much as the GPR status LED I wired in.
Batteries are new;the battery cables have been cleaned up with terminals replaced. I have plenty of juice.
Oil is fresh and full; I run 15W40 Rotella w/Archoil and have no interest in running thinner oils to make up for ****ty injectors.
Glow plug relay works;. I have a status LED wired up in-cab.
Glow Plugs are probably junk; They're definitely some cheap **** from Vatozone that the PO installed. This might explain the hard starts... I have a new Motorcraft set ready to go
Based on my semi-educated research, all signs seem to point to old worn out/crudded up injectors and a few bad glow plugs. Glow plugs are easy but injectors? ... decisions decisions decisions...
The decision I need to make; Whether to calm my inner speed beast and just go with new Alliant stock split shots... OR to up the ante and get some Stage1, 1.5 or 2 sticks from Gearhead with some new tuning and a Hydra (so I no longer have to pull the ECU to update tunes).
My questions for you guys;
- Are my research, troubleshooting and assumptions correct? Are injectors a good idea?
- Considering my concerns (#1 through 6) listed above, what would you do?
If it's glow plugs, you can determine that with an ohm meter. If it's injectors, the easy way is to pull the valve covers and watch the oil discharge at start up and compare it to how it is when warmed up.
I can't help with the smog test thing, so your best bet would be to reach out to Gearhead if those are the tunes you like. Matt should be able to tell you what will and what won't work for smoke and smog tests.
I'm no help on the injectors, ask me again in a year or two. But with that said, you have really described cold start problems, nothing to point at the injectors from my limited knowledge.
As for glow-plugs and relays... I have new-in-the-box Alliant GPR, Motorcraft GP's, Under-cover harness and VC Gaskets ready to go, regardless of the injectors.
That injector test sounds like several VC pulls and a big oily mess... And not very fun on my truck with the 38R intake tube, S&B and Riff Raff couplings. It's a mild pain in the *** to get in there with as tight as all these new parts fit. I'd rather pull them only once.
Is avoiding all that worth the ~$2k gamble? Maybe.. if I get to make another 100 HP and meet all my criteria
"As a very broad average, we typically see normal wear on the oil side of the injector begin to cause drivability, performance, and poor running (particularly on a cold engine) at approximately 200,000 miles. Some trucks have hard cold start, or very low power when cold as early as 165-180k miles…and very few make it past 220,000 miles without some of these symptoms."
That sums up my issues pretty well.
What did your last emissions look like?
I had the same problem you describe, I replaced the GPR, GP and UCVH all needed it but it didn't solve the problem. After a buzz test it was obvious I needed injectors. It turned out 6 of the 8 were original with 352K miles. The new injectors were the problem, last winter the truck started at -4, with 1 GP cycle unplugged. I also run 5w/40 and prior to the last oil change I also ran Archoil.
What tune were you running? Are those single shots?
If you go with sticks be ready for some possiblities (cups, gaskets, harnesses, tuning) that may or may not arise once you go down that rabbit hole.
If it were me I would change out the GPs and see if that did anything since you already have them then go from there. Just my .02
Getting the tuning right wouldn't be a big deal, for ease of changes I would get a new Hydra with any injectors I buy (running T&S cheap-chip now). I hate removing that thing - PITA. Cups would be slightly more tragic but if they are bad... they are bad. I have new gaskets/harnesses sitting in a box with the new GPs. Unless I am missing something, the only real cost here would be the sticks and tunes, maybe cups.
#6 would be fun but is not priority over #1 and #2. I certainly don't mind dropping money on the truck. I'm already so far into it ($$$) that I'll never recover.
Can I really have it all? Will getting the right injectors/tune get me all that I want or is there anything I am missing?
