Fuel issue
Old Jan 20, 2018 | 06:13 PM
LeviD's Avatar
LeviD
Fuel issue
I was testing my tanks before I hooked the fuel line up to my brand newly rebuilt carb as the place informed me of a lot of rust in it. So I flip to my rear tank and and crank it over and collect the gas in glass jars. Sure enough little particles of rust. So I flip to the front tank and crank a few jars worth to flush the system before really looking at the fuel for the front. Front was good so until I replace the rear the front will be the only one I use, cool so I put in my new clear fuel filter and put in new fuel line to the carb because why not. Start cranking and no fuel is getting to the filter. Unhook from carb and still won't pump fuel to it. I don't get what's going on. I replaced the fuel pump during the summer so I wouldn't think it would be bad not to mention it was working minutes prior. Any suggestions on wtf is going on. Pretty frustrated at this point.
Old Jan 20, 2018 | 06:40 PM
LeviD's Avatar
LeviD
Also is it possible of changing the sending unit on a front tank without dropping the tank?
Old Jan 20, 2018 | 06:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Did you flip back to the front tank? If it cranks and does not spit fuel out the line prior to the carb, I'd suspect fuel pump just died. Or your tank sending unit pick up tube filter sock is covered up with crud.
Put some LOW pressure air back down the line just past the fuel pump connection point and see it that helps. Are you sure your tank switch is working?
To NOT drop the side tank and replace the sending unit, I bet you have to pull/lift up the bed. But then again the top of the side tank is slightly angled, so it might work out for ya.
77f150c
Oct 27, 2014 07:07 PM
pgrojean
Oct 11, 2011 08:39 AM
cliffordingles
26
Feb 16, 2011 09:51 PM
wcsd106
Feb 9, 2008 01:13 PM
a_borg
May 23, 2003 07:11 PM
