wiring up outside lights
Old Jan 20, 2018 | 05:50 PM
maineguy53's Avatar
maineguy53
I have a 2012 ford superduty and i have lights that are run with a toggle switch inside . the lights don't work when the truck is shut off or ignition switch is off . i want to run the lights without the switch on , is there a hot wire inside the cab somewhere that i can wire the toggle switch too?
thanks Pete
Old Jan 20, 2018 | 06:14 PM
Chuck's First Ford's Avatar
Chuck's First Ford
power port... aka cigarette lighters... both are Hot...
Old Jan 20, 2018 | 06:37 PM
maineguy53's Avatar
maineguy53
we don't use the cigarette lighter can i unhook them and run it direct to toggle switch and do i nee a inline fuse in there ?
Old Jan 20, 2018 | 06:57 PM
Chuck's First Ford
,,,,,,,,,,,,,YES. and no fuse.. as lighter circuit is fused. 10 amp I think
Old Jan 20, 2018 | 07:02 PM
maineguy53's Avatar
maineguy53
I believe i will need to unhook the battery
Old Jan 20, 2018 | 07:23 PM
Chuck's First Ford
YES,,,,, and YES
Old Jan 24, 2018 | 06:11 AM
maineguy53's Avatar
maineguy53
thanks i got it all set
14SD4Jeffro
Electrical Systems/Wiring
Jan 17, 2015 07:09 AM
Jasonf150
Nov 8, 2014 11:51 PM
rews2
Aug 4, 2014 12:43 PM
D8chumley
2009 - 2014 F150
38
Nov 18, 2013 04:52 PM
tileandstone
Oct 28, 2007 04:01 PM
