ok i have swapped in a low mile e4od trans in to my truck and when i put it in drive i have to rev up the engine to about 2000 rpms just to get it to start rolling is this normal for a trans swap? or is something sticking in the trans it is slowly getting better the more i drive it any help would be appreciated
yes the fluid is fine and it does **** when rolling.... but after driving it a little today (2 miles) i backed it into the barn and the torque converter blew up and maybe the trans i will know more tomorrow.
Can you take photos? I've never seen a torque converter blow up. And I've seen many, many failed transmissions. I've seen torque converters fail internally, but I've never seen one come apart.
i got the trans out the trans is fine and what happened was the little studs that go through the flywheel it wollard out the holes in the fly wheel and broke the studs and cracked the torque converter
You probably have a pressure problem or sticky valve body. Either way I'd drop the pan and valve body to make sure check ***** are in the right places. Your front planet may be toast as well. I had the same issue you were describing but instead of fixing it, I went with a manual
