E4OD issue
Old Jan 23, 2018 | 03:06 PM
lakequ's Avatar
lakequ
how much torque is there supposed to be on the nuts?
Old Jan 23, 2018 | 03:16 PM
Skip1970's Avatar
Skip1970
thats a shot in the nutz huh?
Old Jan 23, 2018 | 05:09 PM
lakequ's Avatar
lakequ
yeah i just got back from carquest and now my wallet is empty (289$)
Old Jan 23, 2018 | 08:11 PM
Briansshop's Avatar
Briansshop
My not so good memory is thinking 28ft/lbs.
Old Jan 24, 2018 | 01:12 AM
Scndsin's Avatar
Scndsin
And you bought a $5 set of locking torque converter nuts to go with that too, right?
Old Jan 24, 2018 | 01:53 PM
lakequ's Avatar
lakequ
i have another set off of a truck i parted out (found them in the glove box)
Old Jan 24, 2018 | 01:54 PM
Skip1970's Avatar
Skip1970
FREEBEEE FREEBEE FREEBEE like on monster garage.
Old Jan 30, 2018 | 07:48 AM
lakequ's Avatar
lakequ
well i put in the new torque converter and flywheel and it was driving better but when i parked it after a short drive it pucked all of the new fluid out. i'm going to check the lines tonight to see if they are clogged and drop the pan to see if i cooked the trans or not
if i have cooked the trans then it will be parts
Old Jan 30, 2018 | 09:43 AM
Briansshop's Avatar
Briansshop
Man that sucks. If it did overheat, might just be the front seal
Old Jan 30, 2018 | 05:24 PM
lakequ's Avatar
lakequ
the nice thing is i'm only in the truck 750$ (not including labor) so i know i can make that much from parting it out
Old Feb 23, 2018 | 06:26 PM
lakequ's Avatar
lakequ
ok i blew the lines out the other day and put fluid in tonight and took her for a drive and its only leaking from one of my lines that i need to tighten. so hopefully tomorrow i'm gonna drive her a little bit and see if everything is good
Old Feb 24, 2018 | 02:25 PM
lakequ's Avatar
lakequ
ok while driving it today it doesn't leak but i think when you put it in drive it starts in 3rd gear because it takes 1500-1750 rpms to start moving but if you put it in first then shift to 2cd then shift to drive its fine does any body know whats wrong
thanks
Quinten
Old Feb 24, 2018 | 02:32 PM
  #28
Briansshop's Avatar
Briansshop
Check the plug at the solenoid valve body.
  #29
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
When the solenoids are not powered the E4OD will start in fourth gear, not third gear. It will still shift manually. I think that's your problem.
Old Feb 24, 2018 | 02:45 PM
  #30
lakequ's Avatar
lakequ
which side is the solenoid body on? is it the one with the shifter or the one by the line hook ups
