No start, no crank
Old Jan 20, 2018 | 08:33 AM
remhaust's Avatar
remhaust
No start, no crank
Just thought I would share even tho not 100% on fix yet. I had a no start problem last week, and there’s another thread by someone with the exact same problem I have or had. I’m not good at linking threads ect or I would. Anyway I tried starting with remote on a cold morning and didn’t hear it start so I tried again and just heard the horn beep. So then we went out to try with key and noticed right away there was no glow plug light or fuel pump running, or mini max not powered up either. Further more later after finding thread I also noticed no check engine light. So finally got to checking fuse 52 & 72 in under hood box and had power at 72 but nothing at 52 or that row of fuses. At first I was like what the hell , then went to try again with test light cuz I couldn’t believe it then as I was probing with tip of test light I heard it come on since second time around I had the key on because I wasn’t sure if that fuse needed key on for power. Works now but haven’t investigated further but suspecting lose fuse or terminal at this time.
Old Jan 23, 2018 | 03:44 AM
golfmedik's Avatar
golfmedik
Wonder if it could have been the big grey connector under the dash just above the parking brake. Several have had trouble with those over the years. Unplug, reseat and go.
Dave Garrison
16
Jan 7, 2019 07:38 AM
AACoPD05
Nov 28, 2017 12:28 PM
jwood464
17
Oct 1, 2012 11:41 PM
bcmchong
Dec 26, 2010 04:05 AM
two9292
Feb 13, 2007 09:58 AM
