CEL random
Jan 19, 2018 | 05:53 PM
CEL random
For the last year I'm getting a random cel... usually happens while cruising. If you accelerate it goes away.. if you brake it goes away..
any ideas?
Jan 19, 2018 | 09:32 PM
Jan 20, 2018 | 06:11 AM
there is literally no way to tell what it is without putting a scanner on and looking for stored codes.
Jan 20, 2018 | 01:07 PM
I have forscan... I'll check it and report back.
Jan 23, 2018 | 05:13 PM
pulled codes:
DTCs in IC: U1059, U1262, B1352, B2658, B1318
DTCs in PCM: P0603, P1316, P0541
DTCs in GEM: P1876
Also ran some tests... got a P1273 and P1275 from injector electrical self test.
Also did KOER Switch Self Test and got P1536, P0220, P1780, P0571, P0703, P0565, P0566, P0567, P0568, P0569, P0541
also did a KOER cylinder contr test: P0248, P0541
Not sure what all these mean... but please let me know if you have any insight.
Andy
Jan 24, 2018 | 05:48 AM
Hm not to scare ya but there’s a lot going on there. Write down the codes and call ford and pick the service depts brain
Jan 24, 2018 | 06:35 AM
Quote:
Originally Posted by
afonda
pulled codes:
DTCs in GEM: P1876
Andy
Are you sure they are all current?
If you haven't done so, it may not be a bad idea to write them all down and clear them to see what comes back.
Jan 24, 2018 | 06:41 AM
Clear them and run the truck for a bit longer to see what comes back. There is a button at the bottom of the screen to delete them.
Jan 24, 2018 | 08:52 AM
Also, regarding the recurring CEL... I have been paying a little closer attention and it seems to come on when the boost is around 5 to 10 psi and will stay on unless you accelerate or slow down.
Jan 24, 2018 | 05:28 PM
well you'll love this...
i went out and cleared all the codes... the P1273 and P1275 codes came back... So, i went to the wire harness and wiggled the wire harness near the UVCH connection on the passenger side. ReRan the test.. the codes did not come back... So, I guess I need a new UVCH for the passenger side. I did the drivers side a little over a year ago.
All this stuff came back though: KOER Switch Self Test and got P1536, P0220, P1780, P0571, P0703, P0565, P0566, P0567, P0568, P0569, P0541
Jan 25, 2018 | 10:00 AM
I went back and read my old thread about loss of power when I had the new injectors put in about a year ago.... turns out I was getting the same P1273 and P1275 codes then as well... strange....
Deadboy214
Mar 15, 2019 01:33 PM
Squirrel13
Sep 29, 2018 05:43 PM
DBGrif91
Aug 9, 2009 08:56 AM
jetedwards
Jul 2, 2008 09:41 PM
felixr
May 10, 2006 07:31 PM
