Sponsored by: Real Truck
V10 tick?? (video attached)
Old Jan 16, 2018 | 09:20 PM
Keeth's Avatar
Keeth
Exclamation V10 tick?? (video attached)
My 01 F350 dually has a tick! doesnt seem to be an exhaust leak, though i do have some. You cant hear the exhaust leak in the video becuase the truck is warmed up, which is why im worried about it. If you tap the gas it goes away, its an on and off kinda of problem so its hard for me to track it down. I was at Taco Bell when i recorded this next to the wall so its easier to hear. When i put this motor in (the old one died at 300,000 miles) i replaced the cam chains and tensioners and guides. I also replaced the oil pump with a DNJ pump. All this was done about 1200 miles ago. I have to take the front cover back off because its leaking oil so if its a lash adjuster i wanna change it then. But i cant seem to pin it down to that. My f250 LD with a 5.4 does the exact same thing and same sound but it doesnt have a exhaust leak. Any help is greatly appreciated. Heres the link:
Any Ideas??
Old Jan 16, 2018 | 10:57 PM
Lawnpro979's Avatar
Lawnpro979
My v10 I that years ago.
I was told that some do.
I think i got used to it, I really dont hear it anymore
Old Jan 18, 2018 | 09:19 AM
speakerfritz's Avatar
speakerfritz
give it gas and it goes away....hmmm
Old Jan 18, 2018 | 02:04 PM
Copper.Farm's Avatar
Copper.Farm
Check your spark plugs.
Old Jan 18, 2018 | 04:28 PM
maticuno's Avatar
maticuno
That sounds pretty normal to me, but mine has headers which translate more exhaust ticks than the cast manifolds did.
Old Jan 19, 2018 | 08:31 AM
lwarrior1016's Avatar
lwarrior1016
Couple of things, was that a rebuilt engine that was installed or a re-manufactured or used?
When you did the timing chains, did you make 100% sure that your tensioners were installed on the correct side, driver being left? I mixed them up one time and it makes the same sound but goes away once oil pressure comes up with rpm.
Lastly, it could be a loose valve guide. That coming from what sounds like the driver rear, that cylinder is the dead head point for coolant so that one will typically be the hottest and the exhaust valve guides can wear out faster on that cylinder.
alabbasi
Oct 22, 2016 11:24 AM
redbull660
Modular V10 (6.8l)
Dec 3, 2011 12:23 PM
9402fordguy
Apr 27, 2011 07:42 PM
Bodaddio
Modular V10 (6.8l)
Jul 18, 2007 06:18 PM
jsmoluk
Jun 24, 2002 02:04 PM
