Sponsored by: Real Truck
Dually front hub adapter difference?
Old Jan 16, 2018 | 02:09 PM
Campsta's Avatar
Campsta
Hey guys, I am new to posting on this forum (but have been creeping on this site for the better part of a year). I have been searching for hours and cant seem to find an answer..
Is there a difference in the 2wd and 4wd front hub adapter on a dually?
Long story short; I got some 05+ wheels for a good price and I was going to convert to 8x200 so I can run these wheels. BUT I want to do it the right way and swap the adapters, and I can only find 2wd trucks being parted out!
Old Jan 16, 2018 | 09:25 PM
texinwa's Avatar
texinwa
Yes, they are the same. How are you going to make the rear match? swap later axles into your existing rear?
Old Jan 17, 2018 | 06:10 AM
Campsta's Avatar
Campsta
Thanks! Regarding the rear... I am either going to do steel spacer/adapters, or re-drill the hubs to 8x200 (I am a machinist during the day). The hub idea makes me a little nervous. I don't know if I will be compromising the integrity of the hub.. OR, I'm wondering if I can buy 05+ hubs and swap completely??
Old Jan 19, 2018 | 10:21 AM
Campsta's Avatar
Campsta
Has anyone else ever changed rear hubs/axle to swap to 8x200?
Old Jan 19, 2018 | 10:45 AM
brandon_oma#692's Avatar
brandon_oma#692
What truck and axles do you have?
Old Jan 19, 2018 | 01:27 PM
Campsta's Avatar
Campsta
Its a 01 DRW with the dana 80
Old May 24, 2018 | 09:11 PM
ufvj217's Avatar
ufvj217
bump in case anyone can help us. the OP (@Campsta) as well as myself are both wanting to convert our dually's to 8x200 to run 05-07 wheels (i want 17's so i can get a larger tire selection for 37x12.50, but don't want aftermarket wheels, i prefer the stock wheel look) but like the OP, i have only been able to find info/figure out how to convert the front using factory parts. just swap the factory front dually "adapter/spacer" to an 05-07 and then the fronts will be 8x200. the rear is what we have not been able to figure out, even months later after this thread was started lol. i started a few threads i think and never got an answer. i can't believe no one in the history of the internet has done this lol!!!
anyway. here's my thinking. it's probably wrong but i'll say it anyway lol.
as far as i know, the front axle is the same in my 04 f350 4x4 as an 05 f350 4x4? maybe the axle is different but the hub on the 05 dually is still 8x170 BEHIND the front wheel adapter. after it, it's 8x200 on 05-07 (not sure about 08+ duallys).
if they only changed the adapter for the front, with the axle/hub itself being 8x170 with no dually adapter installed, did they do something similar on the rear so they didn't have to completely redesign the entire axle/hub? are the wheel studs on the rear of my 04 dually part of the brake rotor? if so, would a rotor from an 05 fit, thus giving me 8x200 in the rear? i doubt it's that easy, but these are things i don't have the answer to and hoping someone here can help me and @Campsta figure out.
OldBlack4x4
Mar 5, 2015 02:52 PM
Friesian-Bronco
Dec 11, 2010 10:41 AM
Raider50
2004 - 2008 F150
Oct 28, 2009 10:13 PM
tfowler306
Jan 24, 2008 10:08 AM
Plummer_62
Sep 25, 2006 10:32 PM
