coil resistor
Old Sep 14, 2003 | 11:39 AM
NJbronco138's Avatar
NJbronco138
coil resistor
Where is the coil resistor on a 91 Bronco? I am getting full voltage to the coil if i replace the resistor that should take care of it? I see one next to the coil, but I was told that for for radio noise. thanks in advance
Old Sep 14, 2003 | 11:54 PM
Franklin2's Avatar
Franklin2
coil resistor
I don't exactly know where it is either, but I believe it's taped up in the harness under the dash. The other thing you are looking at, if it's round and silver is a capacitor, and yes it's for noise. If you want to, you can get a resistor and mount it on the firewall. Some older cars like chryslers used them, and they are a large white ceramic looking thing. Mount it where it will not hurt anything because they do get warm. The Ford manual calls for the value to be 1.05 to 1.15 ohms resistance.
Old Sep 14, 2003 | 11:57 PM
stepman's Avatar
stepman
coil resistor
Are they still using the off-pink wire? if so I beleive it has the resistance built into it.
Old Sep 15, 2003 | 01:13 AM
NJbronco138
coil resistor
I am wondering now if I have one. I was reading somwhere that some trucks have coils with internal resistors.
Old Sep 15, 2003 | 08:35 PM
thelonerangerxlt's Avatar
thelonerangerxlt
coil resistor
NJBronco, I believe your 91 had the "E-type" coil, that didn't require an external balllast.
If you are using an aftermarket coil, you may need to install an external resistor. Some coils have an internal ballast, some don't. If you're not sure, take an ohmmeter and check across the primary windings (small + and - terminals). Anything below about 1.2 ohms needs an external ballast.
Old Sep 15, 2003 | 09:36 PM
NJbronco138
coil resistor
thanks, I will check that out right away.
672wd72highboy
Jun 18, 2014 06:53 PM
1ford1
Sep 7, 2007 07:47 PM
FordMan2
Jul 26, 2007 08:07 PM
Pony Power
Electrical Systems/Wiring
Jul 27, 2006 09:43 PM
82andBlueF150
May 27, 2005 12:12 PM
