Had to change my battery!
Don't forget to follow the instructions in the owner's manual regarding changing the battery and the need to rest the BMS (Battery Management System).
(owner's manual) Don't have one -OR- would like a digital, searchable desktop document?.
-click- the pic'
Goth 150
< This space intentionally -blank- >
Maintence » CHANGING THE VEHICLE BATTERY » Battery Management System ...
*NOTE: FoMoCo dealership service can reset the BMS using their IDS (Intergrated Diagnostic System) negating the eight hours of vehicle sleep time requirement.After battery replacement, or in some cases after charging the battery with the external charger, the BMS requires eight hours of vehicle sleep time (key off with doors closed) to relearn the new battery state of charge. Prior to relearning the state of charge, the BMS may disable electrical features (to protect the battery) earlier than normal.
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
-click- the pic'
Goth 150
