hydro boost swap in a F600?
Ford f650s with cummins run them...
I have looked at the following
4WDB conversion from an F450/F550 using hydroboost
Each caliper is rated at 15k
1991 and later F450s used a 4wdb master that looked pretty easy to adapt
As poster above stated.. all custom.. from firewall reinforcement, rod length, hoses and lines, steering bracket and pump
I may be facing this by default on my F600/F650 axle swap.. further to follow.
I will be making some changes to the brakes on my F700. I don't know yet if I will be going with hydroboost or vacuum. I just know that I am not comfortable driving it on the road with the OEM system.
I don't know what the engineers were thinking with one line from master to booster and one line from booster shared to front and rear. One little leak or issue anywhere in the system and you have no brakes.
So I understand the liability in going custom, but to me any split (front/back) system is a vastly safer option to OEM.
The following users liked this post:
All of the Fords I recall with hydro boost also had girlinger rear brakes. They used two hydraulic pumps as the parking brake was also hydraulic. If GMC ran the steering and hydro boost off the same pump. I do not see why you could not do the same thing. Just follow their pattern.
Have to wire in the electric over ride. Drum-drum, drum-disc, disc- disc valving. Why not?
Greg5OH
26
11-13-2012 12:09 PM
BlueOvalRage
06-01-2010 02:24 PM
Kurt G.
07-10-2007 07:27 AM
gotta56
08-01-2006 03:56 AM
