1978 - 1996 Big Bronco
Tranny Noise,
Old Sep 14, 2003 | 09:36 AM
1stBronc's Avatar
1stBronc
Unhappy Tranny Noise,
'91 Bronco, 351W, E4OD (I think), Need help with whinning noise at cruise and mild acceleration, shifts fine. No noise at idle and hard acceleration and no noise when cold. Any help would be appreciatied. John
Old Sep 14, 2003 | 06:21 PM
greystreak92's Avatar
greystreak92
Tranny Noise,
As long as the shifting is ok and nothing odd sounding other than the whine, I'd suggest a fluid and filter change and see what you get. Might want to get it done by one of the quick lube places that actually evacuate most all of the fluid from the tranny and converter via suction rather than just draining the tranny and refilling. That way you know all of the fluid gets replaced with new fresh stuff. The drain and fill method misses all of the fluid trapped in the converter. Just an option to consider and since your shift points are ok and the shifting feels normal this may be all it needs. Be sure to check for leaks too...tranny cooler lines up to the radiator and if equipped, auxiliary tranny cooler lines are all potential leak points. If fluid can get out, air and crud can get in.
Old Sep 15, 2003 | 09:07 AM
1stBronc's Avatar
1stBronc
Tranny Noise,
Thanks for the input, will flush tranny and change filter this week. John
Snyder518
6.7L Power Stroke Diesel
16
Feb 1, 2016 06:25 PM
303powerstroke
Jan 1, 2016 04:55 PM
roadhouse1979
Sep 30, 2013 06:19 PM
McKenzie7.3
Dec 18, 2011 12:06 PM
V10 CREW
Modular V10 (6.8l)
Jan 13, 2003 11:59 AM
