PAC AP4-FD21 Question non Sony
Old Jan 11, 2018 | 03:34 PM
ssmith100's Avatar
ssmith100
Has anyone used the PAC AP4 in a XLT with the 8" Sync3 with 7 speaker system. I've read that it will work, and I've also read it will only work with the Sony amp based system. Anybody ???
Thanks,
Shane
Old Jan 12, 2018 | 10:31 AM
GABAR's Avatar
GABAR
Thanks,
Shane
This PAC interface is for F150`s and SD that have the Premium Sony System which consist of 10 speakers and a sub woofer.
Does the system in your XLT have a sub woofer or is the Sony name on any of your speakers, sub, and factory amp?
Old Jan 12, 2018 | 11:54 AM
ssmith100's Avatar
ssmith100
No, but according to Crutchfield if you have a XLT with 8" screen and the 7 speaker set up the PAC will work.
Shane
Old Jan 13, 2018 | 03:51 PM
GABAR's Avatar
GABAR
Shane
Crutchfield can be hit or miss with their info so don`t take it as being the truth.
If you go to the PAC website, the info that I previously mentioned is the same on the PAC website.
If you don`t have a factory sub woofer then this PAC interface will not work for you.
Old Jan 14, 2018 | 09:10 AM
orion250's Avatar
orion250
Shane
Try this instead...
FOR-11CK- NO CUTTING FACTORY HARNESS- for the installation of aftermarket amplifier. https://www.amazon.com/dp/B00D9W3CHY/ref=cm_sw_r_cp_apa_ij3wAbVTN986G
It's currently unavailable but you could look elsewhere. Let us know what you end up doing.
Old Jan 14, 2018 | 09:20 AM
Poncho450's Avatar
Poncho450
Not that it helps the OP, but this has been my experience as well.
Crutchfield said that I didn't need an antenna adapter to put a double DIN Pioneer into my Mustang GT. False. Local Best Buy installers told me that I did and pulled one off the rack for me. Install easy after that.
Old Jan 15, 2018 | 10:28 AM
ssmith100's Avatar
ssmith100
One of the guys on the F150 site who has the 8" screen in an XLT without Sony and with center channel has used the PAC AP4 and it worked. I guess I'll be the Guinea Pig.
Shane
Old Jan 15, 2018 | 11:31 AM
acelefty's Avatar
acelefty
Let us know how it goes. I have an XLT with the 7 speaker system with no subwoofer and I would like to add one.
dantheman88125
Apr 15, 2007 10:41 PM
voodoosmooth
Mar 28, 2005 08:04 PM
First Ford Truck
Oct 11, 2003 11:40 AM
Sire_Taz
Apr 25, 2003 02:27 PM
